:: View topic - odstranenie patche bootcore
vendeta40
PostPosted: Thu Sep 08, 2005 8:13 pm    Post subject: odstranenie patche bootcore Reply with quote
Prosim poraddte mi ako mam odstranit patch bootcore robim to podla navodu spustim program x65 flasher dam connect vypise mi zvolte boot method dam ktory kolvek a vypise mi starting service mode ked skonci vypise tuto chybovu hlasku The program failed to read boot password. The procedure exited with error message: No answer from BFC ping co stym?
PostPosted: Thu Sep 08, 2005 9:03 pm    Post subject: Reply with quote
Na odpatchovanie bootcore je potrebne spustit x65flasher s parametrom /b.
dubas_
(člen klubu SM)<br>věrný diskusník
PostPosted: Fri Sep 09, 2005 2:30 pm    Post subject: Reply with quote
dej si na to bacha at to nezkur*is pokud poskodis bootcore tak foun umre natrvalo Sad
MC920 => C45 => CX65 BEST
DavidT
PostPosted: Fri Sep 09, 2005 2:50 pm    Post subject: Reply with quote
A tespoint nefunguje???? Shame on you
S: C65>M75 >Sony Ericsson P1i
Firmware:13
Operátor: Vodafone
Kabel: DCA-510
Stav telefonu: OK
Karta: RS-MMC DV 1024 MB
jenda^^
PostPosted: Fri Sep 09, 2005 2:51 pm    Post subject: Reply with quote
A potom se má zmáčknout tuším, že to je Restore bootcore, nebo tak nějak
Teď mám: Nexus S
dubas_
PostPosted: Fri Sep 09, 2005 2:58 pm    Post subject: Reply with quote
testpoint ti pak nepomuze mobil neni schopnej navazat komunikaci s programy Sad
PostPosted: Fri Sep 09, 2005 3:36 pm    Post subject: Reply with quote
TP je predsa HW uprava, ziaden program nie je potrebny.
dubas_
PostPosted: Fri Sep 09, 2005 4:14 pm    Post subject: Reply with quote
no to jo ale pokud si poskodis bootcore tak foun neni schopnej zahajit komunikaci s ostatnimi programi V-klay,x65 flasher atd. ani po TP Sad
TP je jenom klic k urcitej oblasti v telefonu (ano zde nepotrebujes zadnej soft)
PostPosted: Fri Sep 09, 2005 4:53 pm    Post subject: Reply with quote
@dubas_:
Quote:
Je to miesto na plosnom spoji,ktore ked prerusis,premostis,privedies napatie,tak tym obides bootcore telefonu.
vendeta40
PostPosted: Fri Sep 09, 2005 6:50 pm    Post subject: bootcore Reply with quote
Dik vsetkym za info ale obist sa mi to nedari robil som to podla navodu no furt mi to hlasi tu istu xybu budem musiet kupit tie test point adaptery od martecha este raz dik vendeta
dubas_
PostPosted: Fri Sep 09, 2005 9:08 pm    Post subject: Re: bootcore Reply with quote
nevim jestli sem to dobre pochopil ale ten testpoint kupovat nemusis te si muzes udelat sam
mrkni sem
http://www.benqmania.cz/testpointy.php
