:: View topic - Soft na synchronizaciu kalendara CXT65
bukinko
PostPosted: Fri Sep 16, 2005 1:23 pm    Post subject: Soft na synchronizaciu kalendara CXT65 Reply with quote
zdravim..mam infra a pouzivam MPM ...ale cez tento soft nemozem si upravovat stretnutia, terminy a podobne...velmi by mi to pomohlo...nepoznate nejaky cez ktory by slo upravovat aj kalendar a podobne?Dakujem
dubas_
(člen klubu SM)<br>věrný diskusník
PostPosted: Fri Sep 16, 2005 1:42 pm    Post subject: Re: Soft na synchronizaciu kalendara CXT65 Reply with quote
pouzij Simoco tim to upravis take je to gut soft
MC920 => C45 => CX65 BEST
bukinko
PostPosted: Sun Sep 18, 2005 11:19 am    Post subject: Reply with quote
dik za soft, ale cez ten mi to nejako nejde...nejaky iny neviete?
