Rocky začátečník
Posted: Mon Sep 20, 2004 4:30 pm Post subject: Vypnutí dobijení na USB kabelu. |
Chci se zeptat jestli nekdo nema nejaky trik na vypnuti nabijeni USB datoveho kabelu oznaceno DCA-510 ( spise radu kde asi napajet vypinac na vypnuti a opetovne zapnuti nabijeni ) DIKY PREDEM ZA RADY  _________________ S25,C25,C35,S35,MT50,
CX65 fw 09/12/16/25/36/43 A 408
Kabel DCA-500/510 dle potřeby |
BEZY čestný člen
81.16 SMM
Posted: Fri Oct 01, 2004 8:07 pm Post subject: |
heh, no já mam DCA-510 a je tam takovej caflík, ten stačí posunout a už se to nenabíjí  _________________ C35i -> M35i -> M50 -> CX65 -> SX1McLaren -> SXG75 -> HTC HD
http://www.bezysoftware.net
Brew Mobile Commander 2.0 |
Borix veterán
Posted: Fri Oct 01, 2004 8:13 pm Post subject: |
Taký detailík mám tiež 510, ale knoflíček tam nieje. |
busch čestný člen
 Joined: 29 Feb 2004 Posts: 2675 Location: Praha & Olomouc
27.84 SMM
Posted: Fri Oct 01, 2004 8:17 pm Post subject: |
PINY:
12 - MICEA_AC Analog I External microphone
11 - GND_MIC Analog I for ext. microphone
10 - STEREO2_OUT Analog O driving ext. right to PHANTOM_BUF_OUT with mono-headset STEREO1_OUT and STEREO2_OUT differential mode
9 - GND
8 - STEREO1_OUT Analog O driving ext. headset differential mode
7 - CLK/DCD I/O Clock-line for accessory-bus. Use as DTC in data-operation.
6 - RTS I/O Use as RTS in data-operation.
5 - DATA/CTS I/O Data-line for accessory-bus Use as CTS in data operation.
4 - RX/D- I Serial interface USB-interface full-speed 12Mbit/s
3 - TX/D+ OI/O Serial interface USB-interface full-speed 12Mbit/s
2 - GND
1 - POWER I/O POWER is needed for charging batteries and for supplying the accessories. If accessories are supplied by mobile, talk-time and standby-time from telephone are reduced. Therefore it has to be respected on an as low as possible power consumption in the accessories.
Takže by mělo stačit udělat vypínač na první pin  _________________ Stav dobytka oproti minulému roku nezměněn. Méně krav, ale zato více volů. Také sviní je letos dost.
Nokia 6234, Ericsson T65 |
BEZY čestný člen
81.16 SMM
Pavel Hospůdka kolemjdoucí
Posted: Sat Oct 02, 2004 10:09 am Post subject: Vypnutí dobijení na USB kabelu. |
To Bezy: nejsi rarita - já mám taky USB-510 s tlačítkem na nabíjení ON-OFF.Originál SIEMENS kabel koupenej u T-Mobile za 625Kč |
Borix veterán
Posted: Sat Oct 02, 2004 10:59 am Post subject: |
A nejaké softwarové vypnutie nabíjania neexistuje? |
Posted: Sat Oct 02, 2004 11:06 am Post subject: |
To Borix : a proč potřebuješ vypínat napájení ? Baterii (Li-on) to nevadí,ba naopak.Já nevidím důvod,proč ho vypínat.... |
vcelak badatel
 Joined: 31 Aug 2004 Posts: 149 Location: Ostrava / Opava
Posted: Sat Oct 02, 2004 12:00 pm Post subject: |
Pavel Hospůdka wrote: | To Borix : a proč potřebuješ vypínat napájení ? Baterii (Li-on) to nevadí,ba naopak.Já nevidím důvod,proč ho vypínat.... |
S tím,že to vypínat není potřeba rovněž souhlasím,ale pokud přece jenom chce to nabíjení vypnout,stačí rozebrat konektor a zjistit jakou barvu má kablík k pinu 1 a pak na ten káblík někde iumístit malý vypínač....  _________________ S25 v44, C35i v18 tuned, S35 v25, ME45i v 04 tuned, S55 v91 tuned and QTEK8310 |
vcelak badatel
Posted: Sat Oct 02, 2004 12:04 pm Post subject: |
busch wrote: | PINY:
9 - GND
2 - GND
Takže by mělo stačit udělat vypínač na první pin  |
Kdyz uz jsi u toho pinoutu,urcite jste si vsimli oznace u pinu 3 a 4 USB... Telefony 65 by mely podporovat prime propojeni k pc pres usb rozhrani, uz se na to chystam to vyzkouset. Kdyz to umi nektere motoroly - ty novejsi,tak proc ne siemens... Original kabel pro tento ucel existuje a ma oznaceni DCA-540 pokud se nepletu. S SX1 funguje, zda pujde i s x65 je otazka.... _________________ S25 v44, C35i v18 tuned, S35 v25, ME45i v 04 tuned, S55 v91 tuned and QTEK8310 |
busch čestný člen
27.84 SMM
Posted: Sat Oct 02, 2004 12:30 pm Post subject: |
vcelak wrote: | busch wrote: | PINY:
9 - GND
2 - GND
Kdyz uz jsi u toho pinoutu,urcite jste si vsimli oznace u pinu 3 a 4 USB... Telefony 65 by mely podporovat prime propojeni k pc pres usb rozhrani, uz se na to chystam to vyzkouset. Kdyz to umi nektere motoroly - ty novejsi,tak proc ne siemens... Original kabel pro tento ucel existuje a ma oznaceni DCA-540 pokud se nepletu. S SX1 funguje, zda pujde i s x65 je otazka.... |
jo, prý to jde (osobně nezkoušeno).. ostatně psal sem o tom tady http://www.siemensmania.cz/forum/viewtopic.php?t=2637 _________________ Stav dobytka oproti minulému roku nezměněn. Méně krav, ale zato více volů. Také sviní je letos dost.
KaRLiK_CZ začátečník
Joined: 05 Sep 2004 Posts: 55 Location: Ceske Zlatniky, okr. Most
Posted: Sat Oct 02, 2004 1:42 pm Post subject: |
Ohledne toho vypinani nabijeni pres USB. Ja treba vypinat nabijeni pres USB musim, protoze jinak se V_Klay nspoji s mobilem. Nastesti mam na kabelu prepinac. _________________ 1st : M55 TestPoint (dead - by water) -> CF62 (dead - by force) -> M65 ( live:)
2nd : A50 ( deathless:) -> M55 ( live:)
Ryki začátečník
Posted: Sat Oct 02, 2004 3:32 pm Post subject: |
taky musím vypínat napájení kůli ODt
ODt napíše OK,ale skryté disky se neobjeví _________________ M65:fw43 + patch |
