:: View topic - Pomoc Pri pripijeni s PC
dj0077
2.50 SMM
PostPosted: Wed Dec 21, 2005 5:44 pm    Post subject: Pomoc Pri pripijeni s PC Reply with quote
Ahojjte Chcel by som vas poziadat o radu. Mam taky problem kupil som si cx75 a kabel 540 a nemozem sa spojit s pc mal by som zaujem o patchovanie ale neviem ako a cez aky soft. Dakujem za radu Think
dj007
PostPosted: Wed Dec 21, 2005 5:47 pm    Post subject: Reply with quote
Aby si rozchodil kábel nainštaluj Mobile Phone Manager. Avšak patchovať s ním nepôjde. Je to len dátový kábel.
dj0077
2.50 SMM
PostPosted: Wed Dec 21, 2005 5:56 pm    Post subject: A aky kabel by som mal pouzit Reply with quote
A aky kabel by som mal pouzit? A potom s akym softom?
dj007
pecanz
14931.66 SMM
PostPosted: Wed Dec 21, 2005 5:57 pm    Post subject: Reply with quote
http://siemensmania.cz/forum/viewtopic.php?t=10516 wink
A třeba se softem - V-Klay
dj0077
2.50 SMM
PostPosted: Wed Dec 21, 2005 6:09 pm    Post subject: Dik za Reply with quote
Dik za radu a ked motem poprosit tak este nejaku link na slovensky web na kupenie toho kablu. Applause
dj007
unlockgsm
PostPosted: Thu Dec 22, 2005 7:44 pm    Post subject: datak Reply with quote
ja mam na predaj dat kabel DCA-500, uplne novy za 250sk. ak mas zaujem ozvi sa [email protected]
HenX
PostPosted: Thu Dec 22, 2005 7:56 pm    Post subject: Re: datak Reply with quote
dej to do inzerce
***Sony Ericsson K750i*** The best mobile!!!
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
