:: View topic - zvuk fotoaparatu na cx 75
Goto page Previous  1, 2
samion
PostPosted: Tue Jan 17, 2006 11:06 am    Post subject: Reply with quote
whitewash wrote:
No musis nainstalovat ovladac na emulaciu USB na COM. Najdes ho aj tu na SM
ked to chcem vyskusat cez IrDa, ktory mam v notebooku, treba tiez nejaky ovladac(aky)?
hairy.pecker
PostPosted: Tue Jan 17, 2006 1:55 pm    Post subject: Reply with quote
jesli máš IrDA do USB (což asi máš) tak JO
hobit
whitewash
0.00 SMM
PostPosted: Tue Jan 17, 2006 3:50 pm    Post subject: Reply with quote
V niektorych notebookoch byva IrDA zabudovane...
samion
PostPosted: Tue Jan 17, 2006 7:27 pm    Post subject: Reply with quote
ten IrDa mam zabudovany v notebooku a neviem aky program mam pouzit, aby som sa cez neho dostal do skrytych diskov telefonu, aby som mohol vymazat CameraClickMelody.waw
whitewash
0.00 SMM
PostPosted: Wed Jan 18, 2006 3:35 pm    Post subject: Reply with quote
Skus napriklad toto: Arrow http://forum.www.siemensmania.cz/download.php?file=/software/VSFE021.rar
Je to jednoduche, user-friendly a spolahlive.
Najprv musis mat ale IrDA emulovany ako COM, ak nemas, skus pouzit emulator ktory je na SM, alebo v Win nastavit IrDA na COM.
m@rko
PostPosted: Wed Jan 18, 2006 3:50 pm    Post subject: zvuk fotoaparatu na cx 75 Reply with quote
Zvycajne ovladac pre IrDa v notebooku najde windows. Potom si spusti nejaky programik pre komunikaciu napr. MPM, TotalCommander+plugin(vie hned odkryt aj skryte disky), ...
Potom proste zamenis CameraClickMelody.waw za prazdne wavko
..:: m@rko ::..
- - C55 full tunning > M65@CX70 fw56 Linux tuning, volny pad z 2. poschodia, doteraz funguje a neodvrava. Nepoznam lepsi telefon - -
SMIKEE
(člen klubu SM)<br>táta fóra
Location: Prague,mother of every cities! Telefon:Ukradnut:-(
57422.50 SMM
PostPosted: Wed Jan 18, 2006 4:09 pm    Post subject: Reply with quote
Shame on you LEPŠÍ JE TEN SOUBOR ROVNOU SMAZAT :wink:sorry za caps lock Anxious
Bylo:S65-FW50+RS-MMC-32MB+DCA-510---hafo patchů+VodafoneCZ 8) ----11.5.2006-ukradnut!!
whitewash
0.00 SMM
PostPosted: Wed Jan 18, 2006 4:21 pm    Post subject: Reply with quote
Tiez som za zmazanie... Ked bude treba nahras ho znova z FFSInit.
samion
PostPosted: Fri Jan 20, 2006 2:18 pm    Post subject: Reply with quote
skusal som ten novy comander s pluginom, vsetko som nastavil podla navodu, ale stale mi vypise error hlasenie ked sa pokusim najst telefon
puccik
PostPosted: Thu Jan 26, 2006 10:32 pm    Post subject: Re: zvuk fotoaparatu na cx 75 Reply with quote
samion wrote:
da sa nejakym sposobom vypnut zvuk fotoaparatu na cx 75?
ked mas otvorene diski tak ho bud vimazes alebo nahradis inou nahravkou wink
Drobcek9056
7860.92 SMM
PostPosted: Thu Jan 26, 2006 10:34 pm    Post subject: Reply with quote
TAk pokial ti nefunguje Plugin do TC,tak vyskusaj program ODTool,alebo tusim aj VNavigator ho ma v sebe a potom cez Simoco si ten subor vymazes.
momentalne SL55 Smile
Page 2 of 2
