:: View topic - T9 u Fm23 nefacha V cem je problem?
ozzzi
PostPosted: Mon Mar 13, 2006 10:32 pm    Post subject: T9 u Fm23 nefacha V cem je problem? Reply with quote
Ahoj po nahrani FW23 mi prestala fachat t9,znova sem si nahral a mobil prestal fungovat!tak jsem ji smazal..ted nevim jak ji znova obnovit,pac psani po staru je na pest pomali!diky za pomoc Ozzzi
ozzzi
PostPosted: Mon Mar 13, 2006 10:39 pm    Post subject: T9 u FW23 nefacha V cem je problem? Reply with quote
wosuk
PostPosted: Tue Mar 14, 2006 12:29 am    Post subject: Reply with quote
T9 si muzes stahnout tady. pokud mas S/SL75(proste sou jen trosku jiny Anxious ) tak tady (na fw26 nefunguje Think )
Siemens S8, Alcatel OT easy -> view, N 3310, MT50, M55, S55, S65, S75, SL75 a N73
ozzzi
PostPosted: Tue Mar 14, 2006 3:37 pm    Post subject: Reply with quote
Ähoj už vim jak na to..'T9 na tomto serveru nejde ale funguje ta moje ktera je na serveru [http://www.ozzzi.ic.cz/Siemens/]
