:: View topic - Walky-Talky
Walky-Talky
Moucha
60.08 SMM
PostPosted: Mon May 29, 2006 8:01 pm    Post subject: Walky-Talky Reply with quote
Potrebuju poradit jak si spravne nastavit walky talku u cx70 fw56 u eurotelu u pausalu, ja teda vubec nevim jak to fakci tak s tim potrebuju poradit ma to prej fungovat jako vysilacka ale nevim jestli se za to plati nebo ne
Mio
10930.24 SMM
PostPosted: Tue May 30, 2006 8:13 pm    Post subject: Reply with quote
Shrnu to, protoze se nebudu zbytecne opakovat.
1.) Jde to, ale nevyplati se to neb to pouziva malo lidi
2.) Navod primo neni, ale funguje si nechat nastavit ze stranek BenQ-Siemensu jakoby pro nemeckou sit a pak pozmenit nastaveni podle hodnout Eurotelu v navodu pro Nokie
3.) Pouzij funkci HLEDAT tohoto fora uz se to tu mnohokrat resilo.
LOCK PLS
N95-8GB
Moucha
60.08 SMM
PostPosted: Tue May 30, 2006 8:24 pm    Post subject: Reply with quote
Jo diku snad to nekde najdu
