:: View topic - Langpack pre FW45
Langpack pre FW45
raceman69
PostPosted: Mon Mar 12, 2007 9:03 pm    Post subject: Langpack pre FW45 Reply with quote
kde stiahnem langpack (sk) ,a ako to aplikujem????
JeyJeyko
PostPosted: Mon Mar 12, 2007 9:10 pm    Post subject: Re: Langpack pre FW45 Reply with quote
mno Duku daval link na langpack sem: http://www.siemensmania.cz/forum/viewtopic.php?p=330196#330196
(dole)
a aplikujes ho tak ako to tam pise.S x65flasherom sa spojis s telefonom a das restore...
S8->M35i+kabel->CX75+IRDA,RS-MMC 512Mb->EL71+microSD 512MB,DK-1
fw:45 ElfLoader2
Misisa
PostPosted: Wed Mar 14, 2007 6:23 am    Post subject: Reply with quote
Je nekde moznost stahnout take Langpack lg04 pre E71 na fw45???
Motorola d460,C25,C35,S35,S45i,S55,M65,SX1,M75,SXG75, >>> E71 fw.45+512 kingston
maydayanthem
174.76 SMM
PostPosted: Wed Mar 14, 2007 7:57 am    Post subject: Reply with quote
Hej? A ako ho tam chces potom dat? Nebodaj mas bootkey, resp. si robil TP?
s35 fw18 -> s55 fw91
now cx75 fw25 + e71 fw41 + DCA-510 + DCA-140
samsung D900i -> strasna sracka, ved to ani nie je telefon!
prihlaseny
PostPosted: Wed Mar 14, 2007 8:08 am    Post subject: Reply with quote
langpack aplikovany od duku je funckny, dnes skusane, restore x65flasher, pre isotu zalohu, jedina chyba v preklade je pri BT, prijat data od z BT? je to v anglicite, ostatok vsetko ide
Sefinko
elfmaster
elfmaster
Location: Strážske (Okolie) Telefon: CSL65v53 EL71v45 + 1GB Kingston (c) Benlux
6980.53 SMM
PostPosted: Sun Mar 18, 2007 10:29 am    Post subject: Reply with quote
V anglictine su este aj nazvy zloziek vo Vlastnych Suboroch (Medai Album) Inac ide vsetko ok Smile
JeyJeyko
PostPosted: Sun Mar 18, 2007 10:34 am    Post subject: Reply with quote
ja mam tie zlozky vo Vlastnych suboroch normalne v SK :o
fw:45 ElfLoader2
Sefinko
elfmaster
elfmaster
6980.53 SMM
PostPosted: Sun Mar 18, 2007 10:37 am    Post subject: Reply with quote
A ked spravis fotku tak ti ulozi obrazok kam, mne to vytvori zlozku pictures a zlozku videos a hodi to tam... Cize to len ja to mam anglicky??? Hm..?
mart22
elfmaster
elfmaster
56669.28 SMM
PostPosted: Tue Apr 10, 2007 10:15 am    Post subject: Reply with quote
Pictures a Videos jsou vždy anglicky .... už asi od řady 65
funguje ten Langpack opravdu na e71?
BTW: nevíte jak se zbavit Potvrzení hlášky Povolit Příjem přes bluetooth?. Zkoušel jsem popup killer a místo hlášky to killnulo telefon Laughing
Sefinko
elfmaster
elfmaster
6980.53 SMM
PostPosted: Wed May 30, 2007 7:56 am    Post subject: Reply with quote
Takze uz je to vyriesene v spolupraci s nerow-om tie anglicke nazvy vo Vlastnych suboroch robi patch: "Unlock Folders in Card-Explorer v2.5"
Takze staci ho trocha upravit a budu tam nazvy normalne po slovensky alebo cesky podla nastaveneho jazyka. Staci zakomentovat prvy riadok patchu ako to mam ja a bude to... wink
Code:
* Unlock Folders in Card-Explorer *
;v2.5
;(c) 1nvisible
;EL71v45
;v1 - now you can do everything (cut, copy, view attributes, etc.) with system folders
;v2 - you can move/copy any files anywhere
;v2.5 - now all folders have their native names instead of langpack strings
;072C21B: E3 E1 ;normal names for system folders (Toto treba zakomentovat ako mam ja teraz a nazvy budu opat v slovenskom alebo ceskom jazyku)
0723A50: F0452DE98BDF4DE2 0100A0E31EFF2FE1 ;unlock move/copy for every file
072A21F: 0A EA ;unlock options menu
;072BBC4: 3070F7EB 0000A0E3 ;same icons for locked and unlocked folders
