:: View topic - Diskusia o elfoch pre telefóny Sgold3
Goto page Previous  1, 2, 3, 4, 5, 6 ... 11, 12, 13  Next
JeyJeyko
PostPosted: Tue May 01, 2007 8:05 am    Post subject: Reply with quote
Duku wrote:
Neviem ci ta to este zaujima...vsimol som si to az teraz ked som nieco hladal. Entrypoint pre vypnutie aj restart je vo FL.
Aha,diky...ja som to medzitym vyriesil inak (provizorne),ale idem si to hned prepisat Very Happy
Dik
S8->M35i+kabel->CX75+IRDA,RS-MMC 512Mb->EL71+microSD 512MB,DK-1
fw:45 ElfLoader2
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Tue May 01, 2007 8:10 am    Post subject: Reply with quote
A spisal si nakoniec nejake tie entrypointy? Chcel som sa do toho pustit, ale je toho dost a ja nemam moc casu, tak ci to uz nahodou nemas...
>Daruj krv<
JeyJeyko
PostPosted: Tue May 01, 2007 10:35 am    Post subject: Reply with quote
hej cosi som spisal...Take zakladne co som potreboval.Ale ak chces tak mozem este nejake doplnit a uploadnut to...
fw:45 ElfLoader2
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Tue May 01, 2007 12:41 pm    Post subject: Reply with quote
jj, upni to pls Smile
>Daruj krv<
majsi
100.32 SMM
PostPosted: Tue May 01, 2007 1:31 pm    Post subject: Reply with quote
http://www.edisk.cz/stahni/64612/entrypoints.txt_5.97KB.html
snad to je vsetko wink
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Tue May 01, 2007 1:38 pm    Post subject: Reply with quote
ooooo diky Very Happy
>Daruj krv<
JeyJeyko
PostPosted: Tue May 01, 2007 2:11 pm    Post subject: Reply with quote
juuu pekne Very Happy
je tam toho "trosku" Smile viac ako som mal ja...
Dik
fw:45 ElfLoader2
P4priX
128.03 SMM
PostPosted: Tue Aug 07, 2007 7:29 pm    Post subject: Reply with quote
Sefinko wrote:
CPUD v0.3beta3
(c)NForce, The TrIFoN
(r)benj9
(s)The TrIFoN
Moze pracovat v tychto rezimoch:
- Auto rezim - nastavuje frekvenciu 208MHz vsade okrem mainscreen
- je mozne samostatne nastavit napevno drzanie frekvencie 208, alebo 54 MHz
- Smart rezim - ak je vytazenie procesora mensie ako 80% - prepina sa na frekvenciu 52MHz a naopak
- pre spravnu funkcnost su potrbne funkcie "221" a "222" nachadzaju sa tu: FunctionLibrary v7.2
Když si nastavím smart mód, tak sice mi jde na mainscreenu krásně nevytíženej procesor na 52MHz, ale když spustím vNES a maria tak se strašně seká, nevíte čím to? Zatím sem to nastavil na Auto a běží to dobře, ale procesor je i na MS skoro pořád na 208MHz
Sefinko
elfmaster
elfmaster
Location: Strážske (Okolie) Telefon: CSL65v53 EL71v45 + 1GB Kingston (c) Benlux
6980.53 SMM
PostPosted: Tue Aug 07, 2007 9:46 pm    Post subject: Reply with quote
Patous007 wrote:
Sefinko wrote:
CPUD v0.3beta3
(r)benj9
(s)The TrIFoN
V nastavovacom subore by malo ist nastavit od kolkych percent by sa mal procesor prepinat na 52MHz skus sa s tym pohrad, nastavit to na menej, ja som to este neskusal ale hadam by to malo ist wink
Sefinko
elfmaster
elfmaster
6980.53 SMM
PostPosted: Tue Aug 07, 2007 9:48 pm    Post subject: Reply with quote
mohol by si uploadnut znova pls wink
P4priX
128.03 SMM
PostPosted: Tue Aug 07, 2007 10:45 pm    Post subject: Reply with quote
No a nic takovýho tam nemám... mám tam jen možnosti - Off,Auto,Smart,52,208 a nic dalšího...
Sefinko
elfmaster
elfmaster
6980.53 SMM
PostPosted: Wed Aug 08, 2007 6:49 am    Post subject: Reply with quote
Ja som to tam upadatoval na verziu v0.3beta3 v nej to uz ide nastavovat: http://www.siemensmania.cz/forum/viewtopic.php?p=344580#344580
P4priX
128.03 SMM
PostPosted: Wed Aug 08, 2007 9:01 am    Post subject: Reply with quote
To já taky, volba smart je přece až od nový verze, ne?
Sefinko
elfmaster
elfmaster
6980.53 SMM
PostPosted: Wed Aug 08, 2007 9:10 am    Post subject: Reply with quote
Volba Smart bola od v0.3b1 a v bete2 pribudlo nastavenie volby hlasenia o spusteni a v bete3 pribudlo zasa nastavenie volby Smart, od kolkych percent ma pracovat
mart22
elfmaster
elfmaster
56669.28 SMM
PostPosted: Wed Aug 15, 2007 11:13 am    Post subject: Reply with quote
Diskmon: je nějaký náročný, protože s ním běží procesor na Mainscreenu na 208 MHz.
Extrainfo12: taky je náročné, pořád 208 MHz, navíc by se ve verzi 12 mělo LOcked a unlocked řešit tak že by mělo být nejdřív rozbalovací menu Locked a unlocked a potom až jednotlivé prvky a ne že pod každým prvkem je volba Locked a unlocked. Navíc tam nejde nastavit barva a se GPN2 symboly to dělá černý čtvereček okolo písmen
CPUD:U volby Auto by se hodilo aby to dávalo 52 i při spořiči.
Page 5 of 13
