:: View topic - S65 - premiestnenie SMS
beefer
PostPosted: Tue May 15, 2007 12:11 pm    Post subject: S65 - premiestnenie SMS Reply with quote
cafte potreboval by som presunut SMS z S65 do poitaca alebo prip. ineho mobilu na PC mam BT a IRDA ale nejak sa mi to nepodarilo potrebujem na to servisny kabel?
@urel
595.45 SMM
PostPosted: Tue May 15, 2007 1:18 pm    Post subject: Reply with quote
Nie nepotrebuješ servisny kabel stači ti Bt alebo IrDA
Siemens večne živý.
My tuning
@urel OS Hacker Edition EL71
@urel Mac OS S65
beefer
PostPosted: Tue May 15, 2007 1:50 pm    Post subject: Reply with quote
ak mozes das postup? bo dak mi to nejde
@urel
595.45 SMM
PostPosted: Tue May 15, 2007 2:09 pm    Post subject: Reply with quote
Spustiš Program SiMoCO ak ho nemáš tak ho Stiahni/Download
V hornej lište daš --Nastavení--Nastaviš Com Port----Klikneš OK--
Pod tým je-- Prijate SMS, Odoslané SMS, a klikneš SMS Mobil-----
--A pod tým je --Sim--, a pri tom klikneš Interní--Klikneš pravým na tu SMS-ku
A dáš---Export .csv Excel---Vybrané riadky---
A máš tvoju sms-ku skopirovanu v PC
Siemens večne živý.
My tuning
@urel Mac OS S65
beefer
PostPosted: Tue May 15, 2007 2:54 pm    Post subject: Reply with quote
prepac ja som uplny tupec do siemensov atp. ale ako zistim alebo co to je ten COM port? Embarassed
beefer
PostPosted: Tue May 15, 2007 4:25 pm    Post subject: Reply with quote
robim to pre brata a mi povedal ze ci to potom dostane do SE k610i alebo ako ich tam dostat priamo?
beefer
PostPosted: Wed May 16, 2007 11:32 am    Post subject: Reply with quote
UP
@urel
595.45 SMM
PostPosted: Wed May 16, 2007 12:32 pm    Post subject: Reply with quote
Najednoduhšie riešenie:
Klikni na tu SMS a daj poslať Ďalej.
Siemens večne živý.
My tuning
@urel Mac OS S65
beefer
PostPosted: Wed May 16, 2007 1:17 pm    Post subject: Reply with quote
v mobile ci SiMoCo? bo ked v mobile bratovi som to navrhoval ale ma tam cez 100 SMS a platit zrovna za nich... Shocked
martin-v
PostPosted: Wed May 16, 2007 1:42 pm    Post subject: Reply with quote
vytáhni je přes simoco do počítače, jak psal @urel, jen místo vybrané řádky dej celý seznam. V excelu je ulož jako textový soubor, a ten pak nahraj do toho SE. Nevím, jestli umí otvírat texťáky sám od sebe nebo potřebuje nějakou java aplikaci. Možná taky bude roblém s kódováním češtiny. Musíš si s tím trochu pohrát a vyzkoušet různé formáty (ANSI, UTF-8, Unicode...), ale jiné řešení jak to přenést, aniž bys to musel přeposílat, nevidím.
Ericsson T10 -> T18 + ChatBoard -> Siemens S45 -> S45i -> ME75 fw22 + DCA-510
beefer
PostPosted: Wed May 16, 2007 1:48 pm    Post subject: Reply with quote
ok dik ale jak zistim ktory COM port mam nastavit?
@urel
595.45 SMM
PostPosted: Wed May 16, 2007 1:50 pm    Post subject: Reply with quote
Simoco---nastavení--Vyhladavat---
Siemens večne živý.
My tuning
@urel Mac OS S65
beefer
PostPosted: Wed May 16, 2007 8:03 pm    Post subject: Reply with quote
thx 4 all keby som mal este otazky tak sa ozvem Very Happy
