:: View topic - Patchovanie cez irda
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Řada x72, x75
koliny
PostPosted: Sun Aug 19, 2007 1:01 pm    Post subject: Patchovanie cez irda Reply with quote
Chcem by som sa spitat ci nema niekto niejake skusenosti s alternativnimi sposobmi aplikovania patchov. Vo faqu je sice napisane ze cez irda to nieje mozne ale nieje niejaky sposob ako napriklad opathovanie flashe a nasledne rozbalenie pretoze cez virtualny irdacomport sa dostanem aj ku skrytym polozkam v mobile
PostPosted: Sun Aug 19, 2007 1:07 pm    Post subject: Reply with quote
Nieje to možné, ak by to bolo, tak je tu dávno návod wink
coyotelada22
PostPosted: Sun Aug 19, 2007 2:18 pm    Post subject: Reply with quote
aj ked sa dostenes do skrytych diskov, cez BT/IRDA to zatial nie je mozne
> 1 GB MS DV RS MMC Apacer
> 16 GB Micro SD class 2
>JBenchmark1 27 638 bodov
koliny
PostPosted: Sun Aug 19, 2007 3:00 pm    Post subject: Reply with quote
A nieje sposob ako rozbalit flash soubor a dostat sneho disky cache , config a data?
coyotelada22
PostPosted: Sun Aug 19, 2007 3:12 pm    Post subject: Reply with quote
cez SMELTER si otvoris FF a ulozis si subory
koliny
PostPosted: Sun Aug 19, 2007 4:03 pm    Post subject: Reply with quote
Nebolo by mozne opathovany flash rozbalit a nasledne rozbalene subory nakopirovat a nechat prepisat do mobilu cez simoco alebo iny manager?
Je to mozne?
coyotelada22
PostPosted: Tue Aug 21, 2007 7:31 pm    Post subject: Reply with quote
nie nie a nie aj keby i tam skopiroval konfiguracne nastavenia patchov pre MP
tak ti tam budu nanic
koliny
PostPosted: Sun Oct 14, 2007 8:50 am    Post subject: Reply with quote
Ale s grafickymi patchmi by to malo byt mozne ne.
Thompson
trvalý ban
trvalý ban
PostPosted: Sun Oct 14, 2007 8:52 am    Post subject: Reply with quote
Ne je to totální kravina patchovat přes irda Prosím o lOcK
S6-ME45-M65+hodně patchů-CX75180mhz
@urel
595.45 SMM
PostPosted: Sun Oct 14, 2007 9:14 am    Post subject: Reply with quote
Ano je tu jedno riešenie: Cez servisný kábel si rozbehneš El 2,3.
Spraviš zložku 0:\Zbin\img a do nej kopíruješ png cez Irda.
Ale ako sa tu už písalo cez Irda sa patchovať nedá takže LOCK.
Siemens večne živý.
My tuning
@urel OS Hacker Edition EL71
@urel Mac OS S65
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Řada x72, x75 All times are GMT + 1 Hour
