:: View topic - Nápady na elfy
Nápady na elfy
Goto page Previous  1, 2, 3 ... , 10, 11, 12  Next
132978.34 SMM
PostPosted: Thu Jan 24, 2008 7:17 pm    Post subject: Reply with quote
jj, nějaká taková Cool
podle mě to není zas tak nereálný Smile
PostPosted: Thu Jan 24, 2008 10:02 pm    Post subject: Reply with quote
nerow vyzera to fajn. Len xcelo by to prelozit do CZ Brick wall
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Thu Jan 24, 2008 10:09 pm    Post subject: Reply with quote
A SK by nestacilo? Laughing
>Daruj krv<
PostPosted: Thu Jan 24, 2008 10:10 pm    Post subject: Reply with quote
Duku jasne ze stacilo Smile Mame ? Razz
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Thu Jan 24, 2008 10:44 pm    Post subject: Reply with quote
No tak viac menej mame Mr. Green
http://www.edisk.sk/stahni/05589/MailViewer.elf_23.85KB.html
Ale je to prelozene len tak aby bolo a to prve slovo v hlavnom menu som nenasiel Mr. Green
A potrebujes aj MailDaemon. Ten daj do Daemons Wink
>Daruj krv<
PostPosted: Thu Jan 24, 2008 10:48 pm    Post subject: Reply with quote
Duku thaaaaaaaaaaaanks Applause
Bubak27
PostPosted: Wed Feb 13, 2008 10:58 pm    Post subject: Reply with quote
Mel bych takovy navrh na elf nebo upravu elfu xtask.Kdyby se nekomu podarilo to udelat tak jako je na wm Xbar.Podobny styl jako je elf FastRun.
EL71 FW45 + Elpack 2.3 + 1Gb Kingstone + Windows mobile 6
===C65-Fw43-50-56==>CSL65 Fw53===
= Motorola MPx220 (death) =
nerow
tuner
tuner
8011.36 SMM
PostPosted: Wed Feb 13, 2008 11:47 pm    Post subject: Reply with quote
Super nápad Smile který by se hodil hodně do WM6 tng...
jinak podle mě je to reálné..dalo by se nastavit pozadí, potom pár položek z extra infa a pridat panel z fast runu a máme novy elf Smile
Bubak27
PostPosted: Wed Feb 13, 2008 11:50 pm    Post subject: Reply with quote
Ano tak nejak sem to myslel a prave i to tveho tng Nerow.Skoda ze v cecku moc neumim hned bych se do toho pustil.
nerow
tuner
tuner
8011.36 SMM
PostPosted: Wed Feb 13, 2008 11:52 pm    Post subject: Reply with quote
jj ono by stačilo trochu umět v cecku a pak bys to už ze zrojáku poskládal...když tak napíšu evilfoxovi to je jeden rusák, ale už ted mi dluží 2 elfy, který jsem si u něj poručil Mr. Green
Bubak27
PostPosted: Wed Feb 13, 2008 11:56 pm    Post subject: Reply with quote
Zkusim postahovat par elfu pokud sezenu nejaky zdroj svn a zkusim neco poskladat.
LumkaCZ
4280.50 SMM
PostPosted: Thu Feb 14, 2008 12:01 am    Post subject: Reply with quote
Spíš udělejte něco na styl HTC Task Manager nebo HTC CLOSE X Very Happy . Taky mně to kdysi napadlo ve spojení s task managerem SX1 ale nemělo to odezvu. Tyjo ještě že mám už WM PDA jinak bych se zbláznil Embarassed
HTC TyTN + 1GB miniSD + pouzdro, handsfree, kabel + WM5 (čekám na pořádnou ROM 6.5)
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Thu Feb 14, 2008 9:27 am    Post subject: Reply with quote
...když už tady mluvíte o nápadech na elfy... jeden dost složitej bych měl Very Happy jde o kombinaci screenshooteru a xtasku... při přechodu do xtasku by se udělal screen, který by se zmenšil na šestinovou velikost... xtask by byl s grafickou nástavbou - tzn vybíralo by se přímo z obrázků spuštěných procesů a popisek by byl buď úplně nahoře nebo úplně dole... asi to není reálné a bylo by to dost zátěžové na systém, ale byla by to krása pro tunery Wink Angel
-> Nokia Lumia 800
PostPosted: Fri Feb 15, 2008 11:17 am    Post subject: Reply with quote
Nedal by sa spravit elf ktory by zapinal GPRS podla potreby ?
Bubak27
PostPosted: Fri Feb 15, 2008 11:21 am    Post subject: Reply with quote
Podle potreby? koho? ceho? Zkus to prosim nejak upresnit.
Page 11 of 12
