:: View topic - Elfpack pro SGOLD - otázky a odpovědi
Goto page Previous  1, 2, 3, 4, 5  Next
der_Bär
PostPosted: Tue Feb 19, 2008 2:46 pm    Post subject: Reply with quote
could anyone of you please give a short explanation in english how to apply elfpack 2.3 with mp14 on my s65?
stavca
113.22 SMM
PostPosted: Tue Feb 19, 2008 9:31 pm    Post subject: Reply with quote
it's easy, just download elfpack 2.3 and MP14, go to link contained in the MP14 and download all of these patches and patches depending on them, then aply elfpack, BFL-big function library, cutheap and simply all of these patches and as the last aply MP14, but before that create folder 0:\Misc\Patches\ptc and u can install java aplication master-midlet, but u can install it later (it is used for configuration of patches depends on the MP) and everything should be OK Wink
Guliwer
90.34 SMM
PostPosted: Tue Feb 19, 2008 11:17 pm    Post subject: zbin Reply with quote
Nemohl by my tady nekdo upnout zbin slošku na m65 please.
Siemens M65>CX70, SE K800i, DCA-510
stavca
113.22 SMM
PostPosted: Wed Feb 20, 2008 11:40 am    Post subject: Reply with quote
tady mas link, je to ale na CX70, takze si budes muset nekde najit CSMlist pro M65, jinak ti bude XTask PXovat nebo psat bludy Wink
http://czshare.com/179339/Yybk/ZBin.rar
der_Bär
PostPosted: Wed Feb 20, 2008 5:07 pm    Post subject: Reply with quote
thanks for the explanation, but i'm still unable to do it...
i've downloaded and applied following patches:
elfpack 2.3
library
mainscreen dispatcher
pictures addon
bfl
swi-hook
and mp14
i got some warnings in vklay and ignored them (already thougt that would lead to nothing)
could someone please make a concrete list, which patches are needed for elfpack 2.3 & mp14?
maugliknm
Phone: EL 71,E71
645.34 SMM
PostPosted: Wed Feb 20, 2008 5:41 pm    Post subject: Reply with quote
der_Bär
remove swi-hook and aply Cut heap
S 65 fw 58, M(CX) 75 fw 13,S 75 fw 47+,EL 71 fw 45,E71 fw 45 all MP 14 + EP 2.3
Jabber conference [email protected]
http://www.imghosting.eu/gallery.php?u=maugliknm
der_Bär
PostPosted: Wed Feb 20, 2008 5:59 pm    Post subject: Reply with quote
ok but where do i get this cutheap patch? cant find it here and cant find it on patches.kibab.com
stavca
113.22 SMM
PostPosted: Wed Feb 20, 2008 6:06 pm    Post subject: Reply with quote
yeah, u can find it here Wink go to section Patche and select ur phone model and find the cutheap patch Wink
der_Bär
PostPosted: Wed Feb 20, 2008 6:16 pm    Post subject: Reply with quote
sorry cant find it for s65 :shock:
if u can find it pls give me the link
god i feel so f**king stupid :mg:
stavca
113.22 SMM
PostPosted: Wed Feb 20, 2008 6:42 pm    Post subject: Reply with quote
u r right, it's not there, so it's not important for S65 with FW58 maybe Smile on my CX70 it works OK without CutHeap, but I have it aplied for sure Smile
der_Bär
PostPosted: Wed Feb 20, 2008 6:58 pm    Post subject: Reply with quote
as i said ;) well i tried it without, but the phone just crashes as i start it...
well thanks anyway ;)
stavca
113.22 SMM
PostPosted: Wed Feb 20, 2008 7:13 pm    Post subject: Reply with quote
it was doing me the same, so I aplied EP2.3, then some FL and BFL -more is better and conflicts just ignore Wink cause u r aplying some functions, which u aplied earlier Wink then try to aply API patch (maybe isn't contained in EP) and MP14 Wink if it still crashes, aply lower MP(11 or 5) Wink
michalkopecky
13617.60 SMM
PostPosted: Wed Feb 20, 2008 7:35 pm    Post subject: Reply with quote
it could be missing functions in big fuction library. this looks like its symptoms. try to completize your BFl from other resources or download here from siemensmania.
http://droidik.blogspot.cz
der_Bär
PostPosted: Fri Feb 22, 2008 10:31 pm    Post subject: Reply with quote
ok big thanks @ all, finally i got it;) but it doesn't matter anymore, my s65 has some big errors (resulting fromsome accidents like falling on the ground and other things in the last 2 years^^) and will be replaced by the ef81 (which will hopefully arrive comming monday or tuesday)
igimas
PostPosted: Wed Jul 30, 2008 6:40 pm    Post subject: dotaz (začátečník) Reply with quote
Zdravím, právě jsem se dozvěděl o těchto Elf aplikacích, ale nějak mi to nelze zprovoznit. Abych řekl pravdu, tak ani moc nechápu ten návod, co přesně mám udělat. Například co mám teda dát do složky ZBin a pak ty patche kam umístit. Kam dát ten Master midlet(ani mi nelze spustit). Poradíte mi pls někdo? Mám E71.
Page 3 of 5
