:: View topic - Phonecode zablokovany
Stexer
PostPosted: Fri Aug 08, 2008 8:57 pm    Post subject: Phonecode zablokovany Reply with quote
Cawte chalani, viem ze to je uz stary mobil, Siemens S75 ale dodrbal sa mi tam kod telefonu, viete s tym niekto pomoct?
piste pls na mail: [email protected]
kozino
2156.42 SMM
PostPosted: Fri Aug 08, 2008 9:05 pm    Post subject: Reply with quote
Pomôže ti kábel DCA-510 a Papua Utils (čo najnovšia).
PostPosted: Fri Aug 08, 2008 10:13 pm    Post subject: Reply with quote
Stexer ak si v blizkosti BB tak ti to spravim Smile
Stexer
PostPosted: Sat Aug 09, 2008 9:52 pm    Post subject: Reply with quote
heh BB je daleko ja sm zo Senca.. ale skusim to cez ten kabel
EDIT: no kamo skusal som tu papuu a tak ako mi to vypisalo okienka ščščžščžšč Smile je celkom sranda takze nejdem to risovat
PostPosted: Sat Aug 09, 2008 10:16 pm    Post subject: Reply with quote
skus si stiahnut nejaku inu papuu ,.,.a podla navodu ,. http://www.siemensmania.cz/content.php?id=716&p=2 položka cislo 12, kde das storno pri ukladani suboru do PC a ukaze sa ti ci ulozit do phonu a das YES ,.., skus ,. aj papopuu si mozes stiahnut ,.,. citatelnu verziu Wink
popr keby si bol moc stoho mimo ,.,. ja som PK ,. mozeme sa dohodnut niekedy ., a pomožem ti s tym Wink
Stexer
PostPosted: Sun Aug 10, 2008 9:56 pm    Post subject: Reply with quote
hej to by bolo super. Premna zamna hocikedy.
PostPosted: Sun Aug 10, 2008 10:13 pm    Post subject: Reply with quote
no ,. teraz idem na tyžden na dovolenku ,.a ja som zo siemensom nerobil uz dobre dlho ,.,.ale tak kabel mam este a snad si nieco aj pamatam Mr. Green ,.,.ale kod phonu nebol nikdy problem Wink
