:: View topic - kabel pro c65
kabel pro c65
smrkos
Guest
PostPosted: Tue Jan 04, 2005 2:56 am    Post subject: kabel pro c65 Reply with quote
ahoj,mam problem,mam seriovy kabel (pravd. servisni, patchoval sem s nim C55) na kterem funguje C55,M55 a C62, ovsem moje nova C65 ne...je to tim kablem nebo mnou? Question Very Happy
dik..
smrkos
Guest
PostPosted: Tue Jan 04, 2005 2:58 am    Post subject: add Reply with quote
add: kdyz mi ho Mobile Phone Manager hleda (presneji primo Modem Assistant) tak se mi telefon vypne...
T
Guest
PostPosted: Tue Jan 04, 2005 7:07 am    Post subject: Re: add Reply with quote
Špatný kabel....
smrkos
Guest
PostPosted: Tue Jan 04, 2005 7:41 pm    Post subject: Reply with quote
takze koupit novy kabel? ten DCA-510? nekdo tady na foru psal ze mu nefunguje...tak nevim....
lunarni
PostPosted: Tue Jan 04, 2005 7:47 pm    Post subject: Reply with quote
je to kabelem !!!!!!!
Nejlepší mobil???CX65!!!!!!!!!
