:: View topic - potrebujem radu
potrebujem radu
aroman
PostPosted: Mon Feb 21, 2005 6:21 pm    Post subject: potrebujem radu Reply with quote
Brick wall Dal som do cx65 firmware 36 ako sa vratim na 25? dik
PostPosted: Mon Feb 21, 2005 6:24 pm    Post subject: Reply with quote
Nahraj naspat zalohu s FW25.
BEZY
81.16 SMM
PostPosted: Mon Feb 21, 2005 6:26 pm    Post subject: Reply with quote
Pokud nemáš FF s FW25, tak nejdřív musíš nahrát winswup FW16 a na něj pak už můžeš FW25
http://www.bezysoftware.net
Brew Mobile Commander 2.0
PostPosted: Mon Feb 21, 2005 6:32 pm    Post subject: Reply with quote
Toto malo prist az ked zistime ze nema FF. Angel
vbvbvb
PostPosted: Mon Feb 21, 2005 6:45 pm    Post subject: Re: potrebujem radu Reply with quote
najprv si daj winwup 16 tu zo SM a potom 25
aroman
PostPosted: Mon Feb 21, 2005 7:23 pm    Post subject: Reply with quote
preco sa neda stiahnut winswup FW16 ? Pre x65
Guest
PostPosted: Mon Feb 21, 2005 7:28 pm    Post subject: Reply with quote
16 je stabilna a hlavne je oficialna... winswupy su neoficialne
