:: View topic - Umrtveny S55
Umrtveny S55
PeTTr
PostPosted: Fri Feb 25, 2005 3:59 pm    Post subject: Umrtveny S55 Reply with quote
Mam S55 fw20. Zvetsil sem si pamet na 1.7MB, supr Ted sem chtel upgradit fw na fw91 od siemense ale po skonceni nahravani new fw mi to zahlasilo ze komunikace s founem selhala. Mobil nejde zapnout jen hlumene zatroubil. Tak sem zkusil pres v-klay nahrat puvodni flash kterou sem si schoval pri zvetsovani pameti. Mobil je uz ale uplne hluchej. Muzete mi nekdo poradit??
Sem z toho spocenej az na pr.... Think
Dik za kazdou DOBROU radu, PeTTr.
igi
PostPosted: Fri Feb 25, 2005 4:04 pm    Post subject: Re: Umrtveny S55 Reply with quote
telefon sa umrtvil pretoze si mal rozsireny disk-stalo sa to aj mne-pred updatom fw bolo treba spustit format.moju m55 sa mi podarilo ozivit ked som nahral naspat svoju vlasnu zalohu fullflash+zapis do bootcore!
Guest
PostPosted: Fri Feb 25, 2005 4:11 pm    Post subject: Reply with quote
No jo, ale to sem prave udelal jak sem psal. Telefon je uplne mrtvej.
PeTTr
igi
PostPosted: Fri Feb 25, 2005 4:12 pm    Post subject: Reply with quote
PeTTr
a mas aj povoleny zapis do BOOTCORE?
Bond
14861.00 SMM
PostPosted: Fri Feb 25, 2005 4:17 pm    Post subject: Reply with quote
PeTTr
No a máš teda zálohu FF ? ? ?
PeTTr
PostPosted: Fri Feb 25, 2005 4:25 pm    Post subject: Umrtveny S55 Reply with quote
Ano, mam. Pouzil sem FF kterou sem ulozil pred tim pgradem na 1.71MB.
Bond
14861.00 SMM
PostPosted: Fri Feb 25, 2005 4:26 pm    Post subject: Re: Umrtveny S55 Reply with quote
No a jak to dopadlo Question
PeTTr
PostPosted: Fri Feb 25, 2005 4:31 pm    Post subject: Umrtveny S55 Reply with quote
nemel sem povoleny BOOT CORE. po nahrani do founu zstal cely cerny. pak kdyz sem po tom co sem napsal a pocetl odpovedi sem to zkusil znovu zapnout a byl jen modrej displaj. Povolil sem tedy BOOT CORE a flashuju znovu. Doufam ze nemam taky jen tri pokusy jako u pinuuu Think Think
Bond
14861.00 SMM
PostPosted: Fri Feb 25, 2005 4:46 pm    Post subject: Reply with quote
Paráda podařilo se to Applause Applause Applause
PeTTr
PostPosted: Fri Feb 25, 2005 5:03 pm    Post subject: Umrtveny S55 Reply with quote
Tak pro dalsi zajemce o upgrade na fw91.
Pokud mate rozsirenou pamet na 1.71MB, je NUTNE pred vlastni upgradem z original prgramu od siemense zformatovat pamet!! Jinas se sspotite jako ja
PeTTr
Bond
14861.00 SMM
PostPosted: Fri Feb 25, 2005 5:19 pm    Post subject: Reply with quote
Tak se nám to podařilo i bez zformatovaní Applause Applause Dancing
