:: View topic - aky kabel mam?
aky kabel mam?
a123
PostPosted: Fri Feb 25, 2005 6:16 pm    Post subject: aky kabel mam? Reply with quote
Ospravedlnujem sa ak to tu uz bolo ale nenasiel som nic. Ako zistim aky mam kabel? a ci sa s nim da patchovat?
PostPosted: Fri Feb 25, 2005 6:17 pm    Post subject: Reply with quote
*#06#-->viac-->plugged in
a123
PostPosted: Fri Feb 25, 2005 6:19 pm    Post subject: Reply with quote
Diky uz to mam. Mam DCA-500. Da sa s nim patchovat? mam cx65
PostPosted: Fri Feb 25, 2005 6:22 pm    Post subject: Reply with quote
Tusim, ze da. (ak nie opravte ma pls)
MLB
PostPosted: Fri Feb 25, 2005 7:17 pm    Post subject: Reply with quote
Tusim, ze na DCA500 treba zabezpecit externe napajanie.
CX70 fw56
Solomon
Guest
PostPosted: Fri Feb 25, 2005 7:20 pm    Post subject: Reply with quote
Já mám neorigo sériák z gsmcables a patchování mi funguje i bez externího napájení.
BEZY
81.16 SMM
PostPosted: Sat Feb 26, 2005 4:51 pm    Post subject: Reply with quote
Patchovat jde jen s USB kabelem(mimo DCA-540) nebo COM kabely s připojenym napájenim
http://www.bezysoftware.net
Brew Mobile Commander 2.0
