:: View topic - Patche pro S75
Patche pro S75
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
alkaba
10903.00 SMM
PostPosted: Mon Jul 10, 2006 9:57 pm    Post subject: Reply with quote
A další patch s mou menší úpravou Applause
Quote:
;S75v40 - Reset instead of Keylock in RedButtonMenu
;(c) ThE TrIFoN
0344D2E: A8F0F4EA EDF61EEE
13ABA94: 0x21CC 0x054B ; Keylock => Reload
13ABA98: 0x21CC 0x054B ; Keylock => Reload
174B8A4: 4E6F76C49B206E616872C3A174 526573746172746F7661742020 ;Zmeni Nove nahrat na Restartovat v CZ LGP
18E0ED7: 5A6E6F7675 5265736574 ;Zmeni Znovu na Reset ve SK LGP
Takto to vypadá -
»HTC Rose S740 with WM 6.5.3
»HP iPaq 514 with WM6.5.3
»Siemens C65
alkaba
10903.00 SMM
PostPosted: Tue Jul 11, 2006 7:53 pm    Post subject: Reply with quote
Něco pro ty, co mají FW26 a vyšší a nemůžou downgradeovat a tím pádem ani nemůžou vytvořit loader.
http://s65.ic.cz/viewtopic.php?t=23 wink Applause
»Siemens C65
truhlik
elfmaster
elfmaster
8069.50 SMM
PostPosted: Thu Jul 13, 2006 8:23 am    Post subject: Reply with quote
konence!!! dlouhoocekavany patch na skok do menu wap tlacitkem Pray Pray
Code:
;patch na skok do menu wap tlacitkem bez vypinani javy
;S75v32
; (c) truhlik
; (c) (C)Rst7, ThE TrIFoN
;Don't do idle when pressing browser button
03424BA: A9F0E6EC C046C046
;kratky wap -> menu
00414e74: 195341a0 365241a0
Motorola AMIO --> SL45i v56 tuned --> S75 v47 + FFS v40 + map v40 + Flash Patch
Svatky - 06
DApp - 055b
Elfpack.wz.cz Elfpack česky by truhlik Razz
http://sl45i.wz.cz/ SL45i patche
132978.34 SMM
PostPosted: Thu Jul 13, 2006 8:26 am    Post subject: Reply with quote
nebylo by to i pro FW40 Pray
truhlik
elfmaster
elfmaster
8069.50 SMM
PostPosted: Thu Jul 13, 2006 8:47 am    Post subject: Reply with quote
zkus tohle, ale neni to vyzkouseno, tak za to nerucim,...
Code:
41632c: f56741a0 126741a0
03449AE: A8F0E4E8 C046C046
ale podle nekolika lidi, vw fw 40 skok do menu blbne (nejde se vratit zpet), tak uvidis
Svatky - 06
DApp - 055b
truhlik
elfmaster
elfmaster
8069.50 SMM
PostPosted: Thu Jul 13, 2006 11:46 am    Post subject: Reply with quote
a mame tu dalsi port na fw32,
tentokrat velky orbazek volajiciho
Code:
;* Large photo * (c) SiNgle (p) _caine
;(p) truhlik
;S75v32
29bac0: 33 63 ;photo size
42472C: 08 00 ; disable name and phone incall x displacements ;42472C:
424748: 08 00 ; 424748:
424524: 63 7a ; outcall_y_name ; 424524:
424540: 75 8a ; outcall_y_phonenum ; 424540:
424578: 1B 00 ; outcall_y_blankarea1 ; 424578:
42455C: 87 00 ; outcall_y_blankarea2 ;42455C:
4245C6: 2d 16 ; incall_photo_y ; 4245C6:
42437A: 2d 16 ; outcall_photo_y ;42437A:
424730: 63 7a ; incall_y_name ; 424730:
42474C: 75 8A ; incall_y_phonenum ;42474C:
424714: 1B 00 ; incall_y_blankarea1 ;424714:
424768: 87 00 ; incall_y_blankarea2 ;424768:
Svatky - 06
DApp - 055b
alkaba
10903.00 SMM
PostPosted: Thu Jul 13, 2006 11:42 pm    Post subject: Reply with quote
Po dlouhem laborovani ve FF S75-tek sem konecne uspesne portoval patch work with midlets as with files.... Applause Puvodni data byly uplne jine, ale udelal jsem na to fintu proste jsem si ve FF S75v32 skocil na puvodni adresu a vzal jsem nejake data, ktere byly kolem te adresy ty jsem nasel ve FF v40 a postupne odpocitaval az jsem dosel k zaveru
BTW v blizkosti ocekavejte ze portnu patche blacklist a dont close java with outgoing call wink
Quote:
;S75v40
;Work with midlets as files
;(c) SiNgle
;(p) alkaba
5290BC: 31F1F2ED0028 FEF748FE0128
»Siemens C65
alkaba
10903.00 SMM
PostPosted: Fri Jul 14, 2006 10:13 pm    Post subject: Reply with quote
Dneska zase těžká nuda tj. další port patche Rolling Eyes
Tentokrát odstranění Start asistenta pro FW40...btw D1 se docela blbě portuje Razz
Quote:
;* Disable "Assistant" at startup *
;S75v40
;(c) SiNgle
;(p) alkaba
02FAEED: D1 D0
»Siemens C65
SenorKohucik
3004.72 SMM
PostPosted: Sat Jul 15, 2006 2:39 pm    Post subject: Reply with quote
alkaba nespravis ten patch na restart aj do slovenskeho LGP?Pliss Applause Applause Applause
alkaba
10903.00 SMM
PostPosted: Sat Jul 15, 2006 3:25 pm    Post subject: Reply with quote
wink
»Siemens C65
jakovpc
PostPosted: Fri Jul 21, 2006 10:57 am    Post subject: Nefunkcni Master Midlet ? Reply with quote
Nefunguje mi zadny s patchu, ktery je vazany na Master Midlet, po stisku Vzdalene synchronizace a po restartu se nic nezmeni. Jinak Midlet sporadane modifikuje soubor configs.txt v Misc\Patches\PTC. Co se stane, kdyz provedete refresh (vzdalena synchronizace) vidite ze by to neco delalo? Me to nedela nic Brick wall nic Brick wall nic Brick wall ja uz nechci FF Crying or Very sad Pleas Help!
alkaba
10903.00 SMM
PostPosted: Sun Jul 23, 2006 6:31 pm    Post subject: Reply with quote
Dneska jen tak brouzdám po modopu a co nevidím Shocked Applause
Ikonky menu z EF81 (nebo jak se ten rýžák jmenuje) Applause
Download - http://nahraj.cz/show.php?key=47056-acf34
Akorát jedna vada na kráse...není tam ikona foťáku Místo ní je tam ikona vyzvánění... ale to neva..stejně nikdy nepouštím foťák přes menu wink
»Siemens C65
alkaba
10903.00 SMM
PostPosted: Thu Aug 31, 2006 3:47 pm    Post subject: Reply with quote
Dneska jsem se nudil... Rolling Eyes
Quote:
;Move patches config on MMC
;(c) alkaba
+0060000
#pragma enable old_equal_ff
E20: "0:\\Misc\\Patches\\PTC\\configs.txt",00 "4:\\Misc\\Patches\\PTC\\configs.txt",00
E40: "0:\\Misc\\Patches\\PTC\\%08x.ptc",00 "4:\\Misc\\Patches\\PTC\\%08x.ptc",00
E60: "0:\\Misc\\Patches\\Dis\\*.dis",00 "4:\\Misc\\Patches\\Dis\\*.dis",00
E80: "0:\\Misc\\Patches\\Dis\\*.cfg",00 "4:\\Misc\\Patches\\Dis\\*.cfg",00
36C0: 0x000006DC,"0:\\Misc\\Patches\\GPF\\*",00 0x000006DC,"4:\\Misc\\Patches\\GPF\\*",00
#pragma disable old_equal_ff
»Siemens C65
132978.34 SMM
PostPosted: Thu Aug 31, 2006 3:54 pm    Post subject: Reply with quote
btw. co se po aplikaci tohohle patche stane, když vytáhneš MMC??
neudělá mobil píp, chcíp, jako když není vytvořená složka misc/patches ?
alkaba
10903.00 SMM
PostPosted: Thu Aug 31, 2006 4:14 pm    Post subject: Reply with quote
Nic se nestane...ty soubory jsou nabufferovane v pameti wink akorat nevim co se stane kdyz vytahnes mmc a refreshnes
»Siemens C65
Page 8 of 9
