:: View topic - how to crack EL71?
how to crack EL71?
Reply to topic     Forum Index -> Non Czech Languages Here
adam0110
PostPosted: Fri Sep 22, 2006 4:54 pm    Post subject: how to crack EL71? Reply with quote
i'm adam come from China
and i got a elc1 and want to patch it but i failured with the java x75v1
could u kindly tell me how to crack el71 and what kind of java i could use?
where i could download the java program?
or the only way to crack el71 is TP?
appreciate for ur kindly reply
alkaba
10903.00 SMM
PostPosted: Fri Sep 22, 2006 5:01 pm    Post subject: Reply with quote
Only Testpoint... Confused
»HTC Rose S740 with WM 6.5.3
»HP iPaq 514 with WM6.5.3
»Siemens C65
adam0110
PostPosted: Fri Sep 22, 2006 5:08 pm    Post subject: Reply with quote
could u tell me how to tp el71
any pictures or any links?
thanks for ur reply
adigehalil
PostPosted: Sat Oct 07, 2006 12:57 pm    Post subject: Reply with quote
http://siemensmania.cz/testpointy.php
you can find it here.....
than my question;
i want to buy an el71.. but i am wondering how to apply patches to it..
Quote:
Only Testpoint...
why do i need to do testpoint?
View user's profile Send private message Yahoo Messenger MSN Messenger
adigehalil
PostPosted: Mon Oct 23, 2006 1:43 pm    Post subject: Reply with quote
up____up_____up______ Very Happy
132978.34 SMM
PostPosted: Mon Oct 23, 2006 4:08 pm    Post subject: Reply with quote
because there isn´t another way to generate codes...
but very soon will be relased java application to generating codes..
Reply to topic     Forum Index -> Non Czech Languages Here All times are GMT + 1 Hour
