:: View topic - How to capture photos like in Papua Utils?
Reply to topic     Forum Index -> Non Czech Languages Here
maxi-cx75
PostPosted: Wed Jan 31, 2007 2:25 pm    Post subject: How to capture photos like in Papua Utils? Reply with quote
Hi,
I'm a young programmer and I'm already working about a program called Siemens Webcam Utility. I need a source code that can capture image from phone's camera and save it on a hard drive, like in Papua Utils. I'm using Delphi 7.
And I've got one more question. How to send commands (for example AT+CGMM) to mobile? And how to get answers? I'm thinking about something like HyperTerminal.
Can anyone help me?
Arrow AlleJaja.yoyo.pl admin
Arrow DHTML & PHP programmer
Arrow Vista Premium user
Arrow P O L A N D ! ! !
BEZY
81.16 SMM
PostPosted: Wed Jan 31, 2007 2:57 pm    Post subject: Reply with quote
Hi, for Delphi I recomend this library:
http://www.torry.net/vcl/comms/modems/cport310.zip
u can use write or writeStr commands. If you want to read data from port, just place read or readstr into OnRxChar method. (just a hint - this method should happen everytime data arrive into buffure, but it might be unstable - I myself use a Timer with this code:
Code:
if port.InputCount > 0 then
   PortRxChar(port, port.InputCount)
About a code for camera capture - try using Portmon a find out what commands is Papua Utils using
good luck wink
http://www.bezysoftware.net
Brew Mobile Commander 2.0
maxi-cx75
PostPosted: Wed Jan 31, 2007 5:51 pm    Post subject: Reply with quote
Portmon's log with two frames is here:
http://www.mikomiks.yoyo.pl/2_frames.log
I think these brackets and dots (unknown ASCII characters) are parts of an image, but I don't know how to decode that.[/code]
gehstock
PostPosted: Wed Jan 31, 2007 7:15 pm    Post subject: Reply with quote
Code:
procedure TFormMain.ButtonGetCamClick(Sender: TObject);
var
i,x : integer;
addr,size : dword;
begin
      if FixPage<>-1 then begin
       FormCamera.Off := True;
       ButtonStartCamera.Enabled:=False;
       AddLinesLog('Stope...');
       exit;
      end;
      PageControl.ActivePageIndex:=6;
      FormCamera.Off := False;
      FixPage:=PageControl.ActivePageIndex;
//      ButtonStartCamera.Enabled:=False;
//      PageControl.Enabled:=False;
      i:=1;
      ButtonStartCamera.Caption:='Stop';
      StatusBar.Panels[PanelCmd].Text:='Initialisierung der Kamera...';
      AddLinesLog(StatusBar.Panels[PanelCmd].Text);
      ProgressBar.Position:=10;
      if ComOpen then begin
//       Application.ProcessMessages;
       ProgressBar.Position:=20;
       BFC_SecurityMode;
       if BFC_Error<>ERR_NO then begin
        StatusBar.Panels[PanelCmd].Text:='Bekomme keine Antwort von der Status Nachfrage!';
        ErrEndCamClick;
        exit;
       end;
       if Not((bSecyrMode=$11) or (bSecyrMode=$12) or (bSecyrMode = $13)) then begin
        StatusBar.Panels[PanelCmd].Text:='Nur mit berechneten SKEY möglich!';
        ErrEndCamClick;
        exit;
       end;
       if NOT BFC_ReadCameraId(CamParams.id) then begin
        StatusBar.Panels[PanelCmd].Text:='Kann Kamera Sensor nicht erkennen!';
        ErrEndCamClick;
        exit;
       end;
       x:=CamParams.id;
       if (x>14) or (x<0) then x:=0;
       AddLinesLog('Camera sensor ID('+IntToStr(CamParams.id)+'): '+sCameraSensor[x]);
       NewCamParams;
       Sleep(200);
       ProgressBar.Position:=30;
       if NOT SetCameraParameters then begin
        ErrEndCamClick;
        exit;
       end;
       for x:=1 to 15 do begin
         ProgressBar.StepBy(4);
         Sleep(100);
       end;
       BFC_InitHost($06);
       Sleep(100);
       if NOT TakeCameraPicture then begin
         ErrEndCamClick;
         Exit;
       end;
       StatusBar.Panels[PanelCmd].Text:='Empfange Daten...';
//       ProgressBar.Position:=95;
       if NOT ReadCameraToMemStream then begin
         ErrEndCamClick;
        exit;
       end;
//       ComClose;
//       FormCamera.ClientHeight:=240;
//       FormCamera.ClientWidth:=320;
       FormCamera.Image.Picture.Graphic.LoadFromStream(CameraMemStream);
       FormCamera.Caption:='Jpeg: '+IntToStr(FormCamera.Image.Picture.Width)+
       'x'+IntToStr(FormCamera.Image.Picture.Height)+
       ', '+IntToStr(CameraMemStream.Size)+' bytes';
       StatusBar.Panels[PanelCmd].Text:='Bilder '+IntToStr(i);
       FormCamera.Show;
       if CheckBoxAutoSaveJpeg.Checked then begin
        if NOT AutoSaveJpegCamera then begin
         ErrEndCamClick;
         exit;
        end;
       end;
       ButtonShowFormCam.Enabled:=True;
       While not FormCamera.Off do begin
        if NOT CheckCameraParameters then begin
         ErrEndCamClick;
         Exit;
        end;
        for x:=1 to SpinEditTO.Value do begin
         Sleep(100);
        end;
         ErrEndCamClick;
         Exit;
        end;
         ErrEndCamClick;
         exit;
        end;
          ErrEndCamClick;
          exit;
         end;
        end;
        inc(i);
       end; // While
       AddLinesLog('Shutdown Camera...');
       if NOT BFC_GetCameraBuf(addr,size) then begin
        AddLinesLog('Warning: Fehler kann Datenpuffer nicht freigeben!');
       end;
       If (size<>0) and (CamParams.id=7) then begin
        AddLinesLog('Warning('+IntToStr(size)+'): íåóäà÷íîå îñâîáîæäåíèå áóôåðà êàäðà â òåëåôîíå!');
       end;
       if NOT BFC_ShutdownCamera then begin
        AddLinesLog('Error Shutdown Camera!');
       end else begin
        StatusBar.Panels[PanelCmd].Text:='Kamera ist offen.';
        AddLinesLog('Alle Daten: '+IntToStr(i)+'.');
       end;
       ComClose;
       if NOT CheckBoxAutoSaveJpeg.Checked then SaveJpegCamera;
       ProgressBar.Max:=100;
      end; // if ComOpen
      ErrEndCamClick;
end;
function TFormMain.TakeCameraPicture : boolean;
var
begin
       result:=False;
       if NOT BFC_TakeCameraPicture(CamParams.Resolution,size) then begin
         StatusBar.Panels[PanelCmd].Text:='Fehler beim Datenempfang!';
         exit;
       end;
       if size=0 then begin
        AddLinesLog('Timeout 0.7 sec...');
        Sleep(700);
         StatusBar.Panels[PanelCmd].Text:='Fehler beim Datenenpfang!';
         exit;
        end;
         StatusBar.Panels[PanelCmd].Text:='Keine Anzeige möglich!';
         AddLinesLog('Mögliche Gründe:');
         AddLinesLog('1) Falscher Parameter.');
         AddLinesLog('2) Zeitüberschreitung.');
         exit;
        end;
       end;
       result:=True;
end;
function TFormMain.SaveJpegCamera : boolean;
var
F : TFileStream;
begin
       result:=False;
       if (CameraMemStream=nil) or (CameraMemStream.Size=0) then exit;
       FormCamera.Show;
       StatusBar.Panels[PanelCmd].Text:='Bild speichern ca. '+IntToStr(CameraMemStream.Size)+ ' Byte...';
       with SaveDialog do begin
        FilterIndex:=0;
        FileName := IniFile.ReadString('Setup','OldCamFile','.\Camera1.jpg');
        InitialDir := ExtractFilePath(FileName);
        FileName := ChangeFileExt(ExtractFileName(FileName),'');
        if InitialDir = '' then IniFile.ReadString('Setup','DirOld','.\');
        if not DirectoryExists(InitialDir) then
        InitialDir := IniFile.ReadString('Setup','DirOld','.\');
        DefaultExt := 'jpg';
        Filter := 'Jpeg files (*.jpg)|*.jpg';
        Options:=Options+[ofFileMustExist]-[ofHideReadOnly]
        +[ofNoChangeDir]-[ofNoLongNames]-[ofNoNetworkButton]-[ofHideReadOnly]
        -[ofOldStyleDialog]-[ofOverwritePrompt]+[ofPathMustExist]
        -[ofReadOnly]-[ofShareAware]-[ofShowHelp];
        Title:='Bild speichern ca. '+IntToStr(CameraMemStream.Size)+ ' Byte';
       end;//with
       if SaveDialog.Execute then begin
        F:=TFileStream.Create(SaveDialog.FileName,fmCreate);
        CameraMemStream.Seek(0,soFromBeginning);
        if F.CopyFrom(CameraMemStream,CameraMemStream.Size)<> CameraMemStream.Size
        then begin
         StatusBar.Panels[PanelCmd].Text:='Fehler in der Datei '+SaveDialog.FileName+'!';
         F.Free;
         exit;
        end;
        F.Free;
        StatusBar.Panels[PanelCmd].Text:='Bilder speichern '+SaveDialog.FileName;
        IniFile.WriteString('Setup','OldCamFile',SaveDialog.FileName);
        exit;
       end // if SaveDialog.Execute
       else StatusBar.Panels[PanelCmd].Text:='?';
       result:=True;
end;
function TFormMain.AutoSaveJpegCamera : boolean;
var
F : TFileStream;
sJpgFile : string;
begin
       result:=False;
       sJpgFile:='.\Jpegs';
       if not DirectoryExists(sJpgFile) then begin
         if not CreateDir(sJpgFile) then sJpgFile := '.';
       end;
       sJpgFile:=sJpgFile+'\'+FormatDateTime('yymmddhhnnsszzz',Now)+'.jpg';
//    try
       F:=TFileStream.Create(sJpgFile,fmCreate);
       then begin
         StatusBar.Panels[PanelCmd].Text:='Fehler beim Speichern '+SaveDialog.FileName+'!';
         F.Free;
         exit;
       end;
//    finally
       F.Free;
//    end;
       result:=True;
end;
procedure TFormMain.ErrEndCamClick;
begin
      if CameraMemStream<>nil then begin
       CameraMemStream.Free; CameraMemStream:=nil;
      end;
      ButtonShowFormCam.Enabled:=False;
      ButtonStartCamera.Caption:='Start';
      ButtonStartCamera.Enabled:=True;
      FixPage:=-1;
      ComClose;
end;
function TFormMain.ReadCameraToMemStream : boolean;
var
addr,size,len : dword;
Buf : array[0..$fff] of Byte;
begin
       result:=False;
       if CameraMemStream=nil then  CameraMemStream:=TMemoryStream.Create
       else CameraMemStream.Seek(0,soFromBeginning);
        StatusBar.Panels[PanelCmd].Text:='Fehler im Datenpuffer!';
        exit;
       end;
//       AddLinesLog('Àäðåñ áóôåðà êàäðà: 0x'+IntToHex(addr,8));
//       AddLinesLog('Ðàçìåð êàäðà '+IntToStr(size)+ ' áàéò.');
       if (size=0) or (addr=0) then begin
        StatusBar.Panels[PanelCmd].Text:='Datenpuffer ist gleich groß!';
        exit;
       end;
       if size>1024*1024 then begin
        StatusBar.Panels[PanelCmd].Text:='Datenpuffer hat falsche Größe!';
        exit;
       end;
       ProgressBar.Max:=1 + (size div sizeof(buf));
       ProgressBar.Position:=1;
//       Repaint;
       CameraMemStream.SetSize(size);
//       CameraMemStream.Seek(0,soFromBeginning);
       while size>0 do begin
        len:=sizeof(Buf);
        if size<len then len:=size;
        if NOT BFCReadMem(addr,len,Buf[0]) then begin
         AddLinesLog('Lese Blockinhalt...');
          StatusBar.Panels[PanelCmd].Text:='Fehler beim lesen 0x'+IntToHex(addr,8)+'!';
          exit;
         end;
        end;
        if CameraMemStream.Write(Buf,len)<>integer(len) then begin
         StatusBar.Panels[PanelCmd].Text:='MemoryStream: Fehler beim lesen!';
         exit;
        end;
        ProgressBar.StepBy(1); //max +64
        addr:=addr+len;
       end; // while
        AddLinesLog('Fehler îñâîáîæäåíèÿ áóôåðà êàäðà â òåëåôîíå!');
       end;
       If (size<>0) then begin
        AddLinesLog('Fehler('+IntToStr(size)+') îñâîáîæäåíèÿ áóôåðà êàäðà â òåëåôîíå!');
       end;
       ProgressBar.Position:=100;
       result:=True;
end;
procedure TFormMain.NewCamParams;
begin
       CamParams.WhiteBalance:=CamWhiteBalance.ItemIndex;
       CamParams.Brightness:=ScrollBarBrigh.Position;
       CamParams.CompressionRate:=CamCompressionRate.ItemIndex;
       CamParams.ZoomFactor:= CamZoomFactor.ItemIndex+1;
       CamParams.ColorMode := CamColorMode.ItemIndex;
       CamParams.Resolution := CameraPicResolution.ItemIndex;
       if CamFlashCondition.Checked then CamParams.FlashCondition := 1
       else CamParams.FlashCondition:=0;
      AddLinesLog('WhiteBalance: '+IntToStr(CamParams.WhiteBalance));
      AddLinesLog('Brightness: '+IntToStr(CamParams.Brightness));
      AddLinesLog('CompressionRate: '+IntToStr(CamParams.CompressionRate));
      AddLinesLog('ZoomFactor: '+IntToStr(CamParams.ZoomFactor));
      AddLinesLog('ColorMode: '+IntToStr(CamParams.ColorMode));
      AddLinesLog('FlashCondition: '+IntToStr(CamParams.FlashCondition));
end;
function TFormMain.SetCameraParameters : boolean;
begin
       result:=False;
       if NOT BFC_SetCameraParameters(0,CamParams.WhiteBalance) then begin
        StatusBar.Panels[PanelCmd].Text:='Fehler in den Parametern vom Weißabgleich!';
        exit;
       end;
       if NOT BFC_SetCameraParameters(1,CamParams.Brightness) then begin
        StatusBar.Panels[PanelCmd].Text:='Fehler in den Parametern von der Helligkeit!';
        exit;
       end;
       if NOT BFC_SetCameraParameters(2,CamParams.CompressionRate) then begin
        StatusBar.Panels[PanelCmd].Text:='Fehler Fehler in den Parametern von der Kompressionsrate!';
        exit;
       end;
       if NOT BFC_SetCameraParameters(3,CamParams.ZoomFactor) then begin
        StatusBar.Panels[PanelCmd].Text:='Fehler in den Parametern vom Zoom!';
        exit;
       end;
       if NOT BFC_SetCameraParameters(4,CamParams.ColorMode) then begin
        StatusBar.Panels[PanelCmd].Text:='Fehler Fehler in den Parametern vom Farbmodus!';
        exit;
       end;
       if CamParams.FlashCondition > 0 then
        if NOT BFC_SetCameraParameters(5,CamParams.FlashCondition) then begin
        StatusBar.Panels[PanelCmd].Text:='Fehler: Kamera hat keinen Blitz!';
        exit;
       end;
       result:=True;
end;
function TFormMain.CheckCameraParameters : boolean;
var
OldCamParams: T_CamParamVal;
begin
      result:=False;
      OldCamParams:=CamParams;
      NewCamParams;
      if OldCamParams.WhiteBalance<>CamParams.WhiteBalance then begin
        exit;
       end;
      end;
      if OldCamParams.Brightness<>CamParams.Brightness then begin
        exit;
       end;
       sleep(500);
      end;
      if OldCamParams.CompressionRate<>CamParams.CompressionRate then begin
        StatusBar.Panels[PanelCmd].Text:='Fehler in den Parametern von der Kompressionsrate!';
        exit;
       end;
      end;
      if OldCamParams.ZoomFactor<>CamParams.ZoomFactor then begin
        exit;
       end;
      end;
      if OldCamParams.ColorMode<>CamParams.ColorMode then begin
        StatusBar.Panels[PanelCmd].Text:='Fehler in den Parametern vom Farbmodus!';
        exit;
       end;
      end;
      if OldCamParams.FlashCondition<>CamParams.FlashCondition then begin
        exit;
       end;
//        Sleep(200);
      end;
      result:=True;
end;
BEZY
81.16 SMM
PostPosted: Wed Jan 31, 2007 8:05 pm    Post subject: Reply with quote
You have to switch to HEX, find out what is the header and use the rest as the image itself.
Or use the given source code
maxi-cx75
PostPosted: Fri Feb 02, 2007 4:10 pm    Post subject: Reply with quote
gehstock, can you give me full PU's source? These are some functions and variables used in this code you didn't attach.
Of course I'll add your nicks to 'about' window.
gehstock
PostPosted: Sat Feb 03, 2007 1:30 pm    Post subject: Reply with quote
Orginal source can u find here
http://papuas.allsiemens.com/
here a fast Demo App
http://rapidshare.com/files/14694569/Webcam.exe.html
maxi-cx75
PostPosted: Sun Feb 04, 2007 12:56 pm    Post subject: Reply with quote
I konw, but I don't understand any russian word Sad
alkaba
10903.00 SMM
PostPosted: Sun Feb 04, 2007 2:05 pm    Post subject: Reply with quote
http://papuas.allsiemens.com/x65PU079Beta.rar maybe this wink
»HTC Rose S740 with WM 6.5.3
»HP iPaq 514 with WM6.5.3
»Siemens C65
maxi-cx75
PostPosted: Sun Feb 04, 2007 3:36 pm    Post subject: Reply with quote
thanks, that's it
Reply to topic     Forum Index -> Non Czech Languages Here All times are GMT + 1 Hour
