mikpet kolemjdoucí
Posted: Thu Mar 22, 2007 1:46 pm Post subject: A55 - odblokovanie (boot file is not accepted) |
Na uvod chcem poznamenat, ze som precital viacero tem, kde bol rieseny podobny problem, ale vacsinou pre ine telefony a prisiel som k nazoru, ze asi budem musiet urobit Testpoint, ale este predtym sa chcem ubezpecit, ze je to posledna moznost.
Takze mam A55 (ver. 11, ProdDat: 20040419, Variant: U 214), a chcem ho :
1. aspon odblokovat na operatora
2. ak by sa dalo, tak ho prerobit na C55
Mam dva kable - jeden od kamarata - vyzera byt servisny, otvoril som konektor a zapojene boli iba piny 2,3,4 a druhy vlastnej vyroby(odskusany na MT50 s konektorom pre x35) takisto som zapojil iba piny 2,3,4 (samozrejme som pouzil koncovku pre x55).
Postup, ktory som pouzil:
1. pripojil som A55 k PC (najskor pomocou kabla c.1, potom aj c.2) cez COM1
2. spustil som Freiu (najskor v15 potom v18_cracked)
3. v "configuration" som nastavil: COM1, 115200, RTS, DTR, Bootcore bug
4. potom som dal nacitat flash: Read flash from phone, zaskrtol som Firmware, stlacil som OK, ked sa objavila hlaska "Waiting to power on the phone" tak som stlacil kratko cervene tlacitko na telefone, program pokracoval, ale skoncil s nasledovnym vypisom:
FREIA - Engine build 10, Frontend build 9
Thanks goes out for the following:
Maxim, Rolis, Sergey, PapaJoe, Lead,
TheWizard, Jozso (for hardware and cable
support and of course beta testing),
Nico, Victor, Pinker, Tom,
and all the others who supports ...
COMM_LoadBoots : selected phone family is 8
TTY_OpenCOMPort : opening COM1
TTY_OpenCOMPort : baudrate is 115200, DTR is enabled, RTS is enabled
COMM_IsBootRunning : bootcode does not seem to be running
COMM_LoadBoots : Waiting to power on the phone ...
COMM_LoadBoots : phone is powered on
COMM_SendBoot : sending boot 0 for model 8
COMM_SendBoot : waiting for boot ack
COMM_SendBoot : boot file is not accepted
TTY_CloseCOMPort : Closing COM1
5. Potom som zmenil Boot type na Normal, a znovu to skapalo s tymto vypisom:
COMM_SendBoot : sending boot 1 for model 8
6. Tak som este raz zmenil Boot type na Patched bootcore, vypis nasleduje:
COMM_SendSpecialBoot : waiting for boot ack
Niekde som cital, ze pomoze uz len Testpoint, takze som si stiahol Siemens Testpoint Station 3 v1.2 a pozrel som si testpoint pre A55 - je potrebne prerusit tam jeden spoj.
Chcem sa spytat:
1. naozaj musim urobit ten testpoint?
2. ak ano, mam teda prerusit ten spoj, potom zopakovat moj postup s Freiou(aky Boot type mam nastavit? normal?) a po uspesnom odblokovani/prerobeni na C55 mam znovu ten spoj spojit? Alebo ho necham preruseny uz navzdy?
Na tieto otazky sa mi nepodarilo najst odpovede.
Za rady vopred dakujem. |
Krokodýl čestný člen
Posted: Thu Mar 22, 2007 2:42 pm Post subject: |
Ano jedinou šancí je udělat testpoint a Freia nastavit Normal. Zpět nic spojovat nemusíš. Hlavně velmi opatrně na přerušení spoje, aby jsi neřízl i něco jiného. _________________ Zálohovat, zálohovat, zálohovat!!!
mikpet kolemjdoucí
Posted: Thu Mar 22, 2007 2:56 pm Post subject: |
Dakujem za radu. Vyskusam to az doma, lebo v robote nemam potrebne nastroje. Potom dam vediet, ako to dopadlo. |
mikpet kolemjdoucí
Posted: Fri Mar 23, 2007 8:12 am Post subject: |
Takze mam to uz za sebou.
USPESNE !!!
Ale nebolo to az take jednoduche. Prvy problem boli skrutky. Potrebny je nejaky torx klucik, ktory ja samozrejme nemam, tak som sa dal do vyroby vlastneho skrutkovaca. Naskor som si pilnikom upravil jeden taky stary, ale bol z dost makkeho zeleza, a ani velkost som velmi neodhadol, takze sa mi podarilo skoro uplne znicit jednu skrutku(ktora je tiez dost makka).
Potom som to teda zobral profesionalnejsie - obetoval som jeden lepsi(tvrdsi) skrutkovac a tiez som ho opilnikoval - teraz som uz ale pouzil subleru - sirka by mala byt 1,5 mm a hrubka tak od oka, ale dost tenka. Musel som si dat zalezat a vyplatilo sa, tymto skrutkovacom som uz povolil vsetky skrutky(aj tu uz skoro znicenu).
Potom som narazil na druhy problemik - pod ktorym plechovym krytom sa vlasne nachadza ten Testpoint. Trochu som popozeral cez tie dierky a vyskusal som odstranit ten blizsie ku konektoru kabla - a trafil som dobre.
Najvacsi problem ma ale este len cakal - ked som uvidel to miesto, kde treba preskrabat spoj, tak som zistil, ze je to strasne malinke a ten spoj nie je vobec vidiet(ale to som uz niekde predtym cital, ze je to v medzivrstve, takze ma to az tak neprekvapilo). Bolo to uz na hranici mojich oci, takze by sa zisla lupa, ktoru som samozrejme nemal.
Pustil som sa do skrabania - zobral som jeden mensi kuchynsky nozik, dost spicaty a zacal som jemne odstranovat vrchnu vrstvu plosaka. Ocakaval som, ze narazim na jasne viditelnu linku jedneho spoja, ale zdalo sa mi, ze je tam tych spojov viac. Nezostavalo mi nic ine, iba doverovat tym obrazkom, co som nasiel a urobil som hlbsi rez presne na uvedenom mieste.
S malou dusickou som znovu zmontoval telefon dokopy, pripojil som ho k PC a spustil Freiu. Nastavil som Boot type na Normal a ono to zacalo fungovat. Nechcel som tomu verit, ze hned na prvy raz! Asi nie som az take nemehlo :-).
Potom som uz bez problemov pokracoval podla navodu na prerabku A55 na C55 cislo II a vsetko sa podarilo.
Pisem to tu tak obsirne preto, aby aj ostatni, ktori sa este len chystaju robit to co ja, vedeli, co ich asi caka.
Este raz dakujem za radu.
PS: Keby sa mi to nepodarilo, tak by hrozila mensia rodinna kriza - ten telefon bol totiz mojej svokry!!! |
Posted: Fri Mar 23, 2007 1:52 pm Post subject: |
Gratuluji, k trpělivosti a vynalézavosti , víc takových, to by ubylo problémů. _________________ Zálohovat, zálohovat, zálohovat!!!
Fujitsuu začátečník
Posted: Tue Dec 11, 2007 10:42 pm Post subject: |
Momentálně taky řeším odblokování A55 a chtěl bych se zetpat, jestli se pro odblokování musí udělat testpoint u VŠECH A55tek, nebo jen u nekterých séríí (novější, starší)? Případně jak tu danou sérii poznám?
Díky za odpověď. |
kozino věrný diskusník
2156.42 SMM
Příspěvky na SM: 160,- |
Posted: Tue Dec 11, 2007 10:48 pm Post subject: |
Nevie niekto pri ktorých modeloch rady A je potrebný TestPoint na odblokovanie? Lebo ja som odblokoval A52 cez Jokera (BCoreBug) aj bez testpointu. |
mario_liptov administrátor
Posted: Wed Dec 12, 2007 6:35 am Post subject: |
Jednoduche riesenie. Skusit ci ide, a ak nie, tak urobit TP. Osobne som nezistoval, pri ktorych to ide a pri ktorych nie, ale bolo to zavisle aj od verzie SW v telefone. _________________ S6->N5110->N6110->S55->SE630->C65->CX65->C75->CX75->SX1->S65->ST55->SL65->S75->SL75->EF81->S68->EL71Black->EL71Silver->SXG75->C902->HTC Desire->SAMSUNG GALAXY SIII...?
Julda rozumbrada
16.72 SMM
Příspěvky na SM: 200,- |
Posted: Wed Dec 12, 2007 8:56 am Post subject: |
mikpet wrote: | Takze mam to uz za sebou.
USPESNE !!!
Já to dělal s hodinářskou lupou což je fakt dobrá věc, a vždy jsem kousek škrábal a pak ho zkusil připojit, když nic tak jsem škrábal dál. Je to jistější než to vzít z první vody a hned hluboko. _________________ DCA-510 a M65> ME75> A55> CX65>SX1> opět M65; CX75; CX75; PDA FS LooX 420>PDA FS Loox C550
C35i (na alarmu v autě) |
RDT táta fóra
6964.82 SMM
Posted: Wed Dec 12, 2007 11:19 am Post subject: |
kozino wrote: | Nevie niekto pri ktorých modeloch rady A je potrebný TestPoint na odblokovanie? Lebo ja som odblokoval A52 cez Jokera (BCoreBug) aj bez testpointu. |
Já jsem zase normálně pomocí Jokera odblokoval A55 a také bez problému (a bez testpointu). Většinou A55 a A52 (tedy z roku 2003) jdou snadno (a tedy nutnost testpointu není tak častá). Zato třeba A50 nebo C55 (2002) mohou být problémovější ... _________________ | Právě používám: HTC Touch HD |
Jiri.Sko administrátor
Příspěvky na SM: 69,- |
Posted: Wed Dec 12, 2007 5:28 pm Post subject: |
Jo, nebo A57  _________________ A52 + A55 + A70 + C55 + C60 + C65 + C70 + C75 + CX65 + CX75 + E71 + EF81 + EL71 + M55 + MC60 + ME75 + M75 + S45 + S55 + S65 + S68 + SK65 + S75 + SXG75 + SX1
cosby začátečník
Joined: 08 Mar 2007 Posts: 87 Location: Slovakia,Spišská Nová Ves
81.64 SMM
Posted: Wed Dec 12, 2007 7:46 pm Post subject: |
Niektore A55 uz maju od vyroby TP a niektore nie.To tu bolo aj niekde napisane.Ja som nemusel robit TP pri prerabke na C55. _________________ Telefónov som mal mnoho...Teraz:Vivaz & Puma phone+mnoho Siemensov |
Posted: Wed Dec 12, 2007 7:55 pm Post subject: |
2cosby: že by některé A55 měly už TP? To bych ale potom musel ve V_Klayi zvolit možnost A55 testpoint, ne? A mě to jde s Bootcore bug  _________________ A52 + A55 + A70 + C55 + C60 + C65 + C70 + C75 + CX65 + CX75 + E71 + EF81 + EL71 + M55 + MC60 + ME75 + M75 + S45 + S55 + S65 + S68 + SK65 + S75 + SXG75 + SX1
cosby začátečník
81.64 SMM
Posted: Wed Dec 12, 2007 8:03 pm Post subject: |
Mne to tiez neslo cez moznost A55 Testpoint. ale cez Bootcore Bug _________________ Telefónov som mal mnoho...Teraz:Vivaz & Puma phone+mnoho Siemensov |
RDT táta fóra
6964.82 SMM
Posted: Wed Dec 12, 2007 8:51 pm Post subject: |
cosby wrote: | Niektore A55 uz maju od vyroby TP a niektore nie... |
To bylo asi myšleno tak, že se nemusí testpoint vůbec dělat...  _________________ | Právě používám: HTC Touch HD |
