vklatil kolemjdoucí
Posted: Sat Feb 28, 2004 2:24 pm Post subject: Black list S55 |
Nahral jsem do S55 black list a nejak mi nefunguje - at dam cislo do jake koliv skupiny porad mi vyzvani, jako kdybych tam zadnej black list nemel Nevite nekdo kde by mohla byt chyba? |
mISHA badatel
275.16 SMM
Posted: Sun Mar 07, 2004 12:37 pm Post subject: |
sice nevim odpoved ( nezkousel sem to zatim ) ale zajimalo by me toto
;Black Group
;Black Group
;(C)SiNgle
;M55v10
;Released 04.02.04
;Ver 1.1
823082: F08ce00d FA9F303F ;
; Uncomment what you need
; Phone press red button automatic
007F3F30: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 46FC09002D04F08CE00DFAA286309880
007F3F40: FFFFFFFF FA22CA0C
pokud budu mit nekoho v blacklistu, tak telefon nebude zticha, ale okamzite zavesi ( ackoliv by mozna nebylo spatne nejdriv zalogovat volani ) |
mISHA badatel
275.16 SMM
Posted: Fri Apr 02, 2004 12:36 pm Post subject: |
tak je to konecne tady ( hned to musim vyzkouset )
; S55 BlackList original by SiNgle (M55)
; S55 v20
; don't play any sound / vibra when caller is in black list or reject them
; 2004 by ACiD [mrp]
; GSM Development Crew www.gsm-dev.com
; join us at http://www.handyhacking.com/
; improved by amsik (reject caller from blacklist)
; default Black List is the 5th from the top
; change this here: (03 = 1st, 04 = 2nd, 05 = 3rd, ... , 07 = 5th)
003B9A06: FF 07
64B1A2: 8880F08C FA7B009A
003B9A00: FFFFFFFFFFFF 8880F08C46F8
003B9A07: FFFFFFFFFFFFFF 002D02FAA4A6B1
; reject caller, with message 'Call ended':
;003B9A0E: FFFFFFFF DA630E9E
;003B9A12: FFFFFFFF 9880DB00
; or reject caller, with message 'Busy':
003B9A0E: FFFFFFFF DA63C69D
; or don't play any sound/vibra
;003B9A0E: FFFFFFFF 9880DB00 |
mISHA badatel
275.16 SMM
Posted: Fri Apr 02, 2004 12:52 pm Post subject: |
tak jsem to vyzkousel a navim jestli to koliduje s nejakym dalsim mym patchem, ale volani ze zakazaneho cisla zpusobi pipnuti a vypnuti telefonu. ve sluchatku to vyzvani ovsem dal :o)
jo a pri zapnuti je to cele nejake pomale. dyztak dejte vedet jestli mate podobny problem nebo jestli je to jen u me diky nekteremu patchi.... |
Posted: Mon Apr 05, 2004 5:35 am Post subject: |
Pokial by kolidoval,tak Ta na to upozorni...ak nie,tak je do vadny patch. _________________ Kdo umí, ten umí. Kdo neumí, ten čumí. |
mISHA badatel
275.16 SMM
Posted: Mon Apr 05, 2004 7:47 am Post subject: |
hanni wrote: | Pokial by kolidoval,tak Ta na to upozorni...ak nie,tak je do vadny patch. |
ted sem vyhazel vetsinu patchu ( nevim proc mi nesel opetovny zapis fw20 ) kvuli reklamaci, tak to dnes veci ( jestli mi vymeni tlacitka ) zkusim jeste jednou. |
Posted: Tue Apr 06, 2004 5:59 am Post subject: |
OK. _________________ Kdo umí, ten umí. Kdo neumí, ten čumí. |
mISHA badatel
275.16 SMM
Posted: Tue Apr 06, 2004 9:21 am Post subject: |
no tak asi by to chtelo, aby to zkusil jeste nekdo s s55kou, protoze me se nepovedlo ( furt to hlasi chybu ohledne inicializace ) pomoci wsupu tam natlacit cistou fw20 tak sem jen odinstalova par viditelnych patchu. tzn vysledek 0.
jinak kdybych zacal na ciste louce ( musim si sehnat cistej fw20 samotnej pro vklay trebas > ale ne fubu ) tak to pak zkusim trebas jeste raz. |
julus badatel
Joined: 09 Feb 2004 Posts: 102 Location: Brezno - Slovakia
Posted: Wed Apr 07, 2004 4:09 pm Post subject: |
Ten druhy patch od mISHY mi v pohode funguje... z neho mam zapnuty ten BUSY.... a skupina FF 09. jen se mi zda ze pri skonceni hovoru je mobil trosku lenivejsi... asi 1 sekundu mu trva nez se zotavi... |
mISHA badatel
275.16 SMM
Posted: Wed Apr 07, 2004 5:33 pm Post subject: |
julus wrote: | Ten druhy patch od mISHY mi v pohode funguje... z neho mam zapnuty ten BUSY.... a skupina FF 09. jen se mi zda ze pri skonceni hovoru je mobil trosku lenivejsi... asi 1 sekundu mu trva nez se zotavi... |
a muzes mi prosim napsat, ktere mas patche? |
Posted: Thu Apr 08, 2004 7:05 am Post subject: |
mISHA wrote: |
Preco Ti nejde Winswup?Ak mas funkcny fon,tak nezaskrtavaj Precheck a nechaj,nech ho program urobi...musi vsak pripojit zapnuty fon bez SIM karty.Po prechecku ho program vypne a vtedy stlacis kratko cervene tlacitko..je to jednoduche.
V_Klay robi iba FUBU alebo casti FW,takze s nim si nepomozes.Vyskusaj Winswup s Precheckom. _________________ Kdo umí, ten umí. Kdo neumí, ten čumí. |
mISHA badatel
275.16 SMM
Posted: Thu Apr 08, 2004 8:02 am Post subject: |
hanni wrote: | Preco Ti nejde Winswup?Ak mas funkcny fon,tak nezaskrtavaj Precheck a nechaj,nech ho program urobi...musi vsak pripojit zapnuty fon bez SIM karty.Po prechecku ho program vypne a vtedy stlacis kratko cervene tlacitko..je to jednoduche.
V_Klay robi iba FUBU alebo casti FW,takze s nim si nepomozes.Vyskusaj Winswup s Precheckom. |
no opravdu nevim. neflashoval sem telefon prvne tak me to take prekvapilo. no zkusim to jeste jednou az bude vic casu. treba to jen kolidovalo s nejakym softem.
spis me zajima, ktere patche julus ma abych eventualne vykoumal s cim to blbne. |
Posted: Thu Apr 08, 2004 12:32 pm Post subject: |
Pokial je fon funkcny a nemas prerezany testpoint,Winswup by mal ist bez problemov. _________________ Kdo umí, ten umí. Kdo neumí, ten čumí. |
mISHA badatel
275.16 SMM
Posted: Thu Apr 08, 2004 5:17 pm Post subject: |
tak sem to zkusil na cistej foun. a stale stejny problem. dam cislo do skupiny nebrat ( 04 ) a kdyz na telefon zavolam, tak ve sluchatku stale vyzvani, kdezto foun zabzuci, displej ztmavne a vypne se.
je mozne, ze by pomohlo uvedeni pristroje do tovarniho nastaveni? |
Posted: Thu Apr 08, 2004 6:29 pm Post subject: |
Mozno chybny patch...mne napriklad nejde patch na priradenie zvonenia k volajucemu...a pritom je funkcny.Mne sa pri prijme hovoru vypne telefon...kamosovi ide v pohode. _________________ Kdo umí, ten umí. Kdo neumí, ten čumí. |
