:: View topic - Oživenie A65 pomocou Jokera
Goto page Previous  1, 2, 3
SenorKohucik
3004.72 SMM
PostPosted: Mon Sep 10, 2007 9:27 pm    Post subject: Reply with quote
neporady mi niekto ake mam dat hodnoty na kontrast lebo ho niako nemozem nastavit a stale je modry inak fon funguje
http://www.senorkohucik.wz.cz/
PostPosted: Tue Sep 11, 2007 5:33 am    Post subject: Reply with quote
Su take dve zakladne: bud to 49, alebo 99.
DarkLegion
1453.28 SMM
PostPosted: Mon Feb 18, 2008 5:35 pm    Post subject: Reply with quote
zdravim...mam tiez mrtvy A65 a problemy s ozivenim
TP je uspesne urobeny...V-Klay berie telefon normalne ale Joker sa zatal...45 minut nahrava FF a potom to cele nejde odblokovat
stale sa to sekne na tom istom bloku..tu je vypis
Loading BootsModel(A65)...
Sending StartBoot Ok.
Sending MainBoot Ok.
Com2 115200 BAUD: Ok.
SIEMENS A65 lg3 Sw17
Soft FlashID: 0001/2212
FlashID: 0001/227E-2212-2200
Flash Size: 16Mb, WriteBuffer: 32 bytes
Region(1): Blocks 256, Size 64Kb
Start EEPROM segments at addres 0x7C0000
FSN: 9A9F3E35 -> PhoneID: 353E9F9A
OTP IMEI: *****************
HASH: 8C2A55195B07CFF45186768EDA514DA8
Use OTP IMEI: *****************
USE SKEY: 12345678
*#0000*12345678# - Network Lock
*#0001*12345678# - Service Provider Lock
*#0002*12345678# - Corporate Code
*#0003*12345678# - Phone Code
*#0004*12345678# - Network Subset Lock
*#0005*12345678# - Only Sim
BCORE HASH is equivalent - not change.
Read EEPROM addr: 0x7C0000 size: 0x030000...
Error Read Flash block 0x7C0000 size 0x004000!
co to je za chybu..jednu A65 som uz takto opravoval a fungovalo to normalne Think
SIEMENS VEČNE ZIVÝ
Page 3 of 3
