:: View topic - Problemy
Problemy
Goto page Previous  1, 2, 3
Dieg0
19990.28 SMM
PostPosted: Fri Dec 31, 2004 6:25 pm    Post subject: Reply with quote
Hej hej to viem musis si z toho noveho clanku stiahnut program mccx65 a stiahnut si z telefonu do PC setup.fs a tam v tom programe ho das otvorit a dole najdes zoznam funkcii odstran Dynamic lights ze nan kliknes a potom stlacis to cerveny X potom si to uloz na disk a daj to do telefonu.A hura uz tam neni otaznik takto to vislo aj mne aj kamosovi co som to robil.Dieg0.Inak dik za pochvalu no pochvalu podakovanie Smile prva co som dostal Smile.Aspon trochu som uzictocny popri sprostych otazkach.Dodatok : Vsak hanni Smile.
Dieg0
19990.28 SMM
PostPosted: Fri Dec 31, 2004 6:27 pm    Post subject: Reply with quote
A je tam ako keby z CX ten otaznik tiez to nechapem.Zrejme to nenaslo hardver cize diody tak sa namiesto napisu zjavil otaznik.Daj vediet ked to urobis.Dieg0
Dieg0
19990.28 SMM
PostPosted: Fri Dec 31, 2004 6:30 pm    Post subject: Reply with quote
Mimochodom ak to nevies najst stiahni si to odtialto http://diegonet.wz.cz/MCCX65.ZIP tu to je. diego.
scasnyk
PostPosted: Fri Dec 31, 2004 6:46 pm    Post subject: Problem s POZNAMKAMI!!! Reply with quote
Nevie mi niekto poradit co sa stalo s mojimi poznamkami.
Proste mi zmyzli odtial data a neviem ako sa to stalo.
Ak niekto vie, poradte prosim....
Dieg0
19990.28 SMM
PostPosted: Fri Dec 31, 2004 6:48 pm    Post subject: Reply with quote
zaloz vlastnu temu je to OT
oookoook
veterán
veterán
PostPosted: Fri Dec 31, 2004 6:53 pm    Post subject: Reply with quote
Proc? Tohle je topic o problemech. Ma problem, tak to sem napsal, ne? To neni OT. Ted se to sice venuje necemu jinymu, ale to preci nevadi...
Oook Oook!
Dieg0
19990.28 SMM
PostPosted: Fri Dec 31, 2004 7:05 pm    Post subject: Reply with quote
jaj myslel jsem ze tohle je topic jen o ikonach Sad
oookoook
veterán
veterán
PostPosted: Fri Dec 31, 2004 8:44 pm    Post subject: Reply with quote
No podivej se na prvni prispevek... Bylo to o spojeni s pocitacem... Ale uznej, ze Problem to rozhodne je...
Oook Oook!
PostPosted: Sat Jan 01, 2005 1:14 pm    Post subject: Reply with quote
Applause Applause Applause dikes fahci to naplno
Page 3 of 3
