:: View topic - POTREBUJU VRATIT CAMERACLICK MELODY u C65
eTniesXcz
PostPosted: Sat Jan 15, 2005 10:19 am    Post subject: POTREBUJU VRATIT CAMERACLICK MELODY u C65 Reply with quote
Smazal jsem kameraclickmelody nemate nekdo originalni zaloho?vyresi to neco potrebuju to vratit zpet jdu na reklamaci DIKY MOC ZA ODPOVEDI NA MAIL [email protected]
Beberik
(člen klubu SM)<br>začátečník
PostPosted: Sat Jan 15, 2005 10:22 am    Post subject: Reply with quote
Poslal jsem ti ten soubor... Ale na reklamaci ho IMO nebudes potrebovat.
C35i FW18 > C35i FW24T9cz > M55 FW9/FW11 > C35i FW25T9cz > C65 FW12/FW16/FW25 > CSL65 FW50-MP + C72 FW19
eTniesXcz
PostPosted: Sat Jan 15, 2005 10:26 am    Post subject: DIKY Reply with quote
DIKYDIKYDIKYDIKYDIKYDIKYDIKYDIKYDIKYDIKYDIKY Very Happy
No11
PostPosted: Sat Jan 15, 2005 10:29 am    Post subject: Reply with quote
mému známému kůli tomu neuznali raklamaci C(T-mobile)65... tak si to vzal domu, nahrál tam naz5 ten původní a šel tam znova... :o
mot m3888=>mot t2288R => N3310=>N3330=>N3410=>N6310i =>CT65 fw12, FW25,Clear T-mobile, FW33,=>M65 FW12,FW25 patched,FW33 patched, FW41 patched, FW 43 PAtched
eTniesXcz
PostPosted: Sat Jan 15, 2005 10:31 am    Post subject: mam jeste problem Reply with quote
No jo ale ja nevim uz jak ho tam dat pomozte mi i kdyz pouziju OD tak mi to ty config a detauft neukaze jak to???
No11
PostPosted: Sat Jan 15, 2005 10:35 am    Post subject: Reply with quote
Config\Default\CameraClickMelody.wav
Beberik
PostPosted: Sat Jan 15, 2005 11:12 am    Post subject: Re: mam jeste problem Reply with quote
Občas se stane, že OD ty disky neodemkne... Zkousej to vickrat, jednou se to podari.
JenaM
5904.88 SMM
PostPosted: Sat Jan 15, 2005 11:51 am    Post subject: Reply with quote
no skus to vicekrat!!!...ale jinak jsem mel zmenene ikonky v menu chybel click melody...dal jsem ho na prehrani FW do siemensu pod zaminkou chyby...a normalne si toho ani nevsimli!
Guest
PostPosted: Sat Jan 15, 2005 1:45 pm    Post subject: Reply with quote
nebo aplikuj patch na odemknutí slošek... to je 100 procentní..
Guest
PostPosted: Sat Jan 15, 2005 10:10 pm    Post subject: Reply with quote
no jo ale kdyz aplikuje patche tak by mu tu zaruku uz asi neuznali spis!!!!
