:: View topic - Patch na vymazanie zlozky v Card Explolery na S55
SPAKO
vývojář SiemensManie
PostPosted: Sun May 30, 2004 12:43 am    Post subject: Patch na vymazanie zlozky v Card Explolery na S55 Reply with quote
Existuje nejaky patch ktory by pohol tomu, aby som mohol vymazat v Card Explolery zlozku ktora nieje prazdna??
PostPosted: Sun May 30, 2004 2:17 pm    Post subject: Reply with quote
Nato patch nie je.Ale tu zlozku mozes zmazat cez DES.
SPAKO
PostPosted: Sun May 30, 2004 2:45 pm    Post subject: Reply with quote
Neviem co je to ten DES ?
PostPosted: Sun May 30, 2004 3:06 pm    Post subject: Reply with quote
Dataexchange software...program na pracu s Card explorerom.
SPAKO
PostPosted: Sun May 30, 2004 3:18 pm    Post subject: Reply with quote
Aha, no jasne, len ma pomylila ta skratka. Samozrejme to takm robim, ale som to chcel mazat bez pouzita PC, teda rovno z mobilu.
No co pockam, mozno cosi take bude neskor. A DIK
PostPosted: Sun May 30, 2004 3:49 pm    Post subject: Reply with quote
Neviem,ci by to mozno neslo cez servisne menu...ale neviem isto,vyskusaj.
SPAKO
PostPosted: Sun May 30, 2004 3:57 pm    Post subject: Reply with quote
To som uz skusal, ale ta technicka anglina mi robi problemy, ale stale sa tam vrtam, kym tam na nieco rozumne nepridem. Fulflash mam zalohovany, tak nech aj skolabuje. Ak na nieco nove pridem a nielen ohladom tych zloziek, tak sa urcite ozvem.
