:: View topic - POZOR-NEAPLIKOVAT-CHYBNÉ PATCHE S ORIGINAL FW43
jamaica
17095.68 SMM
PostPosted: Wed Mar 23, 2005 7:30 pm    Post subject: POZOR-NEAPLIKOVAT-CHYBNÉ PATCHE S ORIGINAL FW43 Reply with quote
Dneska sem narazil na to že mi s original FW43 od siemensu nefungují tyto patche:
;S65 - Patches for EEPROM
;(c) Siemens Service Profiler by Skylord
+0FEA7C4 ; Start of 71-st block, change it at your own, use Smelter
3D: FF FE ; Enable Band Selection
40: FF BF ; Disable startup Music/Animation
40: BF AF ; Enable Line menu
;S65v43 - Extended "Calls dialed" list
;(c) avkiev
;Green button -> "Calls dialed"
;Red button -> "Calls received"
;Red button -> "Calls missed"
;Red button -> Ready
16BB12C: A779AAA0 110880A0
0800800: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 45787443616C6C7320A961766B696576
0800810: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00B5D7F07FFCD7F079FCD7F089FC00BD
;S65v43 - ????? _????????_ ??????? ??? ???????????? ??????????? ??????????
;S65v43 - Show _current_ time during postponed alarm
;(c) avkiev
0A591B8: 42780178 A7F53CFB
0800820: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 506F7374706F6E416C61726D20A96176
0800830: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 6B69657600B5044A0448011C08319047
0800840: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0248017A427A00BDBB9EC3A0000077A8
dělá Vám to taky někomu?Nevíte někdo v čem je chyba?Jo a všechny sou systémové!
Bůh odpouští, JÁ NE!
LG G2 d802
Mark Pawl
PostPosted: Thu Mar 24, 2005 9:18 am    Post subject: Reply with quote
Já jsem si hodil do phounu patch na cx65 fw43, už nevim kterej Smile, a při najedí do zákl. obrazovky mi mobil chcípnul a zdárek .. A to jsem tam měl jen tenhle patch, zkoušel jsem to. No a Hannimu ten patch jde uplně na tom samym fw i phounu v pohodě, ty céiksa jsou každej prostě originál no Laughing
PostPosted: Thu Mar 24, 2005 10:10 am    Post subject: Reply with quote
A potom som sa mohol divit,preco nikomu nesiel ten moj tuning FF wink
maskot
PostPosted: Thu Mar 24, 2005 10:32 am    Post subject: Reply with quote
Mne enable band selection na cx65v43 funguje...
Motorola T2288 -> A50 -> CXT65 fw. 16 -> fw. 25 -> fw. 36 -> fw. 25 -> fw. 43 -> fw. 50 + patch na 14,74MB (odstraneny) -> prerobeny na CX70 fw. 56
PostPosted: Thu Mar 24, 2005 10:43 am    Post subject: Re: POZOR-NEAPLIKOVAT-CHYBNÉ PATCHE S ORIGINAL FW43 Reply with quote
Nevím jak ostatní patche ale tento předpokládám jsi si generoval z jiné FF, než co máš v telefonu. Pokud upravuješ blok 71 pomocí patche, musíš vždy generovat ten patch z FF na kterou bude aplikovaný. Bloky EEPROM nemají stále stejnou pevnou adresu, proto ti ani nemůže fungovat.
jamaica
17095.68 SMM
PostPosted: Thu Mar 24, 2005 4:42 pm    Post subject: Reply with quote
2 Krokodýl - my si nerozumíme Rolling Eyes To co mi tu říkáš já vim,ale mě tyhle patche všechny normálně fungovali a šli i bezpečně aplikovat dokud sem v telefonu měl swup verzi 43CZ Exclamation Laughing Jak sem přešel na oficial od Siemensu tak nejdou Brick wall Brick wall Brick wall Z toho vyplívá že oficial je trošku jinej než swup,ale ještě sem nenašel v čem. Shame on you Teda snad až na to že ted mi de nahrávat video 1:30 minuty a se swupem šlo jen půl.Nechtěl bys to otestovat u sebe,viděl sem ten patch i pro M65,teda pokud máš ještě swup,zdali Ti to pude Think
LG G2 d802
jamaica
17095.68 SMM
PostPosted: Thu Mar 24, 2005 4:50 pm    Post subject: Reply with quote
jo ps: 2 krorkodýl já ten patch pro eprom sem negeneroval,stáhnul sem si ho z BI,ale ve swup43 prostě šel normálně nahrát bez chybovejch hlášek Brick wall
LG G2 d802
