:: View topic - LED pro výrobu svítilny pro foceni 45.000 mCd utáhne ji M75?
fly2
PostPosted: Sun Jan 29, 2006 6:56 pm    Post subject: LED a jeji parametry Reply with quote
LED bílá 10 mm, GaN x 0,31/y 0,31, 6°, 3,6 V 20mA, 48000 mcd, pouzdro čiré
kwash
303.22 SMM
PostPosted: Sun Jan 29, 2006 8:07 pm    Post subject: Re: LED a jeji parametry Reply with quote
tak potom kde je problem je to v poho,len akurat pri plne nabitej baterke moze ledka odpoxodovat do vacnyx lovist staci teda odkukat na ukazovateli bat,kedy zacne ist pod hodnotu 3.6 a dat tam mini switcher z odporom a bez/pod 3,6V/
CX70fw56+switxing cable DCA-510<->DCA-500,S75 black,N95 8gb
stefan.indian
PostPosted: Sun Jan 29, 2006 8:55 pm    Post subject: Reply with quote
no ja som v slovenskych ešopoch našiel max 20 000mCD, lebo tiez som uz nad tym uvazoval...
ak mate niekto tip kde by sa dalo zohnat velmi vysokosvietiva (ako tu spominana 48Cd) dajte pls vediet Smile
inac ja by som otazku polozil:
AKY JE MAXIMALNY MOZNY ODOBERATELNY PRUD Z BATERKY, tj z PINU 1 a 2 ???
biggeorge
PostPosted: Sun Jan 29, 2006 11:11 pm    Post subject: Reply with quote
lidi, diody nesezerou nic, 20 mA je standard... predpokladam ze veskery vystup z telefonu prezije... tudis, vite-li kam to pripojit, nevahejte Applause
jinak 45000mCa, d=10mm za 35Kc?? to je husta cena
http://flajzar.cz/detail.php?zbozi=846&cat=530&open=
Nokia 3310 -> Siemens MT50 -> M55 -> S75 FW47+FFS+MAP
fly2
PostPosted: Mon Jan 30, 2006 6:14 pm    Post subject: Reply with quote
no ja bych ji zapojil takto:
1 +
2,5,6,7 - Dancing
stefan.indian
PostPosted: Mon Jan 30, 2006 6:31 pm    Post subject: Reply with quote
1 +
2,5,6,7 - Dancing
a preco treba spojit 2,5,6,7 ?
fly2
PostPosted: Mon Jan 30, 2006 7:01 pm    Post subject: Reply with quote
1 +
2,5,6,7 - Dancing
protoze to tu uz bylo ve foru... a jinak nevim... pokud nekdo vite poradte... Pray
guruxxl
PostPosted: Mon Jan 30, 2006 7:04 pm    Post subject: re: led Reply with quote
Neviem ci neviete citat ten datasheet k tej LED alebo co ale tam jasne pisu ze je na 3V(Forwerd voltage-Napetie v priepustnom smere), pricom vsetky LEDky su na toto spominane napetie okrem par vinimiek. A ten prud o ktory sa tolko strachujete, tak vacsina mikroprocesorov, ak je ten vystup nim spinany, ma vystupny zatazovaci prud 20mA, a v pripade nedovery dajte daky maly odpor okolo 50Ohm, alebo si vypocitaje pozadovany prud cez Ohmov zakon.
kesu
14913.56 SMM
PostPosted: Mon Jan 30, 2006 7:27 pm    Post subject: Reply with quote
A schémy zapojení LED pro x75 je stejné jako pro x65?
Já jsem si totiž vyráběl LED svítilnu na CX65,ale ta mi bohužel na SXG75 nefunguje Rolling Eyes
stefan.indian
PostPosted: Tue Jan 31, 2006 4:17 pm    Post subject: Re: re: led Reply with quote
no takze ked spojim 5,6,7 a 2 tak to znamena ze mi zapne nejaku funkciu v procesore, ktore pusti prud medzi 1-2 max 20mA ?
Resp ak nespojim piny 2,5,6,7... iba budem chciet odoberat prud cisto z 1 a 2, tak aky mozny maximalny prud mozno odoberat z x65/x75?
gorgeous007
PostPosted: Tue Jan 31, 2006 6:15 pm    Post subject: Reply with quote
Myslite, ze tato je dobra?
Code:
Dióda LED 5mm biela vysoko svietivá - SUW50010    17000mCd, Oshino      108,00   V čase aktualizácie boli na sklade.
stefan.indian
PostPosted: Tue Jan 31, 2006 6:27 pm    Post subject: Reply with quote
Code:
v sos.sk maju aj 20Cd pokial si spominam
pkas
PostPosted: Tue Jan 31, 2006 10:42 pm    Post subject: Reply with quote
Tak to asi uvedeme na pravou miru, ze...
Maximální proud led diodou bývá okolo 20 až 50mA
Přibližný úbytek napětí na led diodách ULED:
červená - 1,65V
žlutá - 2V
zelená - 2V
modrá - 3,5V
Samozrejme toto jsou "obycejne" LEDky - u tech jinejch je treba se ridit katalogem... Nicmene pokud z telefonu leze nejakejch 3,77V a LEDka je na 3,5V tak si myslim, ze ji to zas tolik neublizi a mela by to zvladnout i bez odporu...
Philips FIZZ -> Nokia xxxx -> Motoshitorola d520 -> C25 -> C35i -> ME45(fw28)....forever -> M75(fw13) + DCA 510 + RS-MMC 512 SanDisk (dead) -> M65(fw50)
milan_ruzicka
PostPosted: Wed Feb 01, 2006 3:42 pm    Post subject: Reply with quote
červená - 1,65V
žlutá - 2V
zelená - 2V
modrá - 3,5V
Mám pocit, že z telefonu lezou ty volty třeba aji čtyři, když je nabitej...
CX65v50
SMIKEE
(člen klubu SM)<br>táta fóra
Location: Prague,mother of every cities! Telefon:Ukradnut:-(
57422.50 SMM
PostPosted: Wed Feb 01, 2006 3:44 pm    Post subject: Reply with quote
Když je telefon nabitý,tak z něj leze 4,1 V Hand wink teda aspoň mě
Bylo:S65-FW50+RS-MMC-32MB+DCA-510---hafo patchů+VodafoneCZ 8) ----11.5.2006-ukradnut!!
Page 2 of 3
