hotter badatel
 Joined: 04 Dec 2004 Posts: 141 Location: Lithuanian Phone: M55 47266.46 SMM
Posted: Sun Jul 03, 2005 4:55 pm Post subject: sw54 for cx70 |
Now i have sw50 in my cx70, but i want to know what is better in sw54? May be i have to update my phone to sw54? |
Onecar veterán
10894.00 SMM
Posted: Sun Jul 03, 2005 5:31 pm Post subject: |
I think that there aren´t any big changes. You can stay at FW50, you may use patches, but FW54 doesn´t have any patches yet. |
szkepek táta fóra
Joined: 17 Jan 2005 Posts: 1269 Location: Konice - největší prdel na jih od Arktidy a na Sever od Sahary
Posted: Sun Jul 03, 2005 6:01 pm Post subject: |
Onecar wrote: | I think that there aren´t any big changes. You can stay at FW50, you may use patches, but FW54 doesn´t have any patches yet. |
There are some patches, did you forget Smelter automatic patches ?
What about FW54 ? Well, it's a little bit faster, and camera was also quite a lot improved (C65 - better colors, noise reduced...) But there aren't any bigger changes. I think, that you won't be OUT, if you stay with FW50
And what about "Smelter auto patches." I advise you patch for faster java for FW54, cause a lot of bugs were repaired.. _________________ Vita Circulus ést !!! |
hotter badatel
Posted: Mon Jul 04, 2005 6:17 am Post subject: |
i cant patch my phone because my phone sw from shop is 43 so the only way to patch is testpoint i think... testpoint is very hard to do so i think i wont do it... :cry: :cry:
So may be i will update my phonr :) |
hotter badatel
Posted: Mon Jul 04, 2005 7:21 am Post subject: |
when i updated to sw54 i had Error on waiting for Stat-Data!!! help my phone didnt turn on :cry: :cry: :cry: |
hotter badatel
Posted: Mon Jul 04, 2005 7:52 am Post subject: |
i tride to put back sw50 to phone but the same error Error on waiting for Stat-Data!!! :cry: :cry: :cry:
is so bad i dont know what to do help me plzzzzz :cry: :cry: :cry: |
Little_S čestný člen
Joined: 29 May 2004 Posts: 733 Location: 48° 45'N 18° 36'E
Posted: Mon Jul 04, 2005 10:23 am Post subject: |
try using official Siemens Update FW43, maybe it'll help, but i'm not sure if it helps, i've never seen an Waiting for Stat-Data error. _________________ Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. |
szkepek táta fóra
Posted: Mon Jul 04, 2005 6:30 pm Post subject: |
Well, I recommend you to use WS version of FW25, than generate kodes (which might be very useful). Then try to get there FW 54.
And what about your prob : I used to have a same one too. It's thing of configuration of your cable. You have a wrong driver, or maybe wrong COM port set in WinSwup. Check it ! _________________ Vita Circulus ést !!! |
Njuska badatel
Posted: Tue Jul 05, 2005 7:13 pm Post subject: |
I noticed: When I receive (and open) some *.txt file which hasnt "right" encoding format (for example UNICODE, UTF-8, Windows 1250...), my phone writes: "cant open"... Before, with FW50 and older my phone always "freeze".
Now, I use ANSI encoding without diacritics. I dont understand why Siemens disable multi support encoding for text files on his phones.
Zatím jsem si všimnul, že pokud přijmu a otevřu nějakej textak, kterej nema správny kodovani (napr. UNICODE, UTF-8, Windows 1250...) tak telefon napise: "Záznam nelze otevřít"... Předtím s FW50 a staršíma mi telefon vždycky zatuh.
Takže ted používam kodovani ANSI bez hacku a carek. Nechapu, proc Siemens na svejch telefonech "zakazal" podporu pro ruzne kodovani textovejch souboru. |
hotter badatel
Posted: Thu Jul 07, 2005 8:41 pm Post subject: |
[quote="szkepek"]Well, I recommend you to use WS version of FW25, than generate kodes (which might be very useful). Then try to get there FW 54.[/quote]
I tryed to do it but my phone sw from shop is 43 so i cant to put sw25,
when i tryed to put it i had error thet phone cant update it, i tryed 3 times and i had the same error :cry: |
