Duku uživatel roka 2008
 Joined: 18 Dec 2004 Posts: 1027 Location: Liptovský Mikuláš Phone: EL71v45 28.71 SMM
Posted: Sun Mar 23, 2008 9:30 am Post subject: Diskusia k funkčnosti patchov E/EL71 |
Mozno sem budu pisat max. 2-3 ludia, ale takato tema mi tu chybala
Tak zacnem
Skusal niekto patch Iconbar enhancement v1.1? Mne sa po aplikovani ikonbar zaplni cervenymi stvorcekmi (1. obrazok vo FW). Sefinko pisal ze mu to robi tiez. Robi to kazdemu?
_________________ EL71 Black FW45 + Kingston 2GB + DCA-110 + DCA-140 + HHS-150
>Daruj krv< |
maugliknm badatel
 Joined: 06 Mar 2007 Posts: 140 Phone: EL 71,E71 645.34 SMM
Posted: Sun Mar 23, 2008 2:15 pm Post subject: |
Ja tam Iconbar Additions nemam. Ked ho chcem aplikovat, v_klay mi hlasi chybu a netusim s cim by to mohlo kolidavat
A neviem o ziadnom patchi s iconbarom ze by som tam mal neviem Ale tiez tam mam toho dost...
Ten patch s tymi SMS veru nemam chut skusat Ja SMS vacsinou mazem, takze ho nepotrebujem
>Daruj krv< |
maugliknm badatel
Posted: Sun Mar 23, 2008 4:44 pm Post subject: |
ot a mas aplikovany Sound on data transfer request v2-MP mne prestal fungovat po aplykovani niecoho ineho a s opravnym patchom som daval iba elfpack a Functions Library a to ich mam celkovo asi 100
_________________ S 65 fw 58, M(CX) 75 fw 13,S 75 fw 47+,EL 71 fw 45,E71 fw 45 all MP 14 + EP 2.3
Jabber conference [email protected]
http://www.imghosting.eu/gallery.php?u=maugliknm |
SPIKEBOY čestný člen
maugliknm badatel
Posted: Mon Mar 24, 2008 10:32 am Post subject: |
prave sa divam na iconbar enhancement v1.1 el71 fw 45 a data
05C09F4: 00213C30002206C004C0 00488047,0xA006A619,C046
05C0A24: E7480C224830E449 00488047,0xA006A629
05C0A56: DB480C224830D74937F2 014880470000,0xA006A629
05C0AD6: BB480C224830B74937F2 014880470000,0xA006A629
05C0DE4: 291C062037F216EA0E1C 00498847,0xA006A639,C046
05C0E08: 0C21 C046
05C0F54: 9F4874390E804E800C2248309D4937F2 74390E804E80014880470000,0xA006A629
05C13E6: 988A062802D906209882 C046,00488047,0xA006A653
05C143C: 998A062901D3062819D268480C22311C 00498847,0xA006A669,C046,014880470000
05C144C: 683036F2 0xA006A629
05C149C: 06220092514A6800 004A9047,0xA006A68D
05C14DC: 68005C32115A0C233C3A 00488047,0xA006A6B3,C046
05C14F6: 3C4A1030040468005C32 C046,004A9047,0xA006A6C9
05C1510: 0C23 C046
sa zhoduju s E 71 , mozno je probem niekde tam,nezda sa mi ze by EL a E mali rodielne iba adresy na ktorych je patch ulozeny,ide to niekomu na E 71 ????????????
Posted: Mon Mar 24, 2008 1:24 pm Post subject: |
A co sa ti na tom nezda? To je normalne ze data su rovnake a len adresy rozdielne.
maugliknm wrote: | ot a mas aplikovany Sound on data transfer request v2-MP mne prestal fungovat po aplykovani niecoho ineho a s opravnym patchom som daval iba elfpack a Functions Library a to ich mam celkovo asi 100 |
Ten patch nemam. Ja s opravnym patchom vacsinou radsej nedavam. Elfpack davam hned na cistu FF tak s nim tiez nastastie nemam problem.
>Daruj krv< |
maugliknm badatel
Posted: Mon Mar 24, 2008 7:03 pm Post subject: |
Aplikovalo mi ho bez chyby a v ikonbare mi pribudla ikona vibracii a gprs, ale zmizli mi iconbarclock.
Kolidovat ti to moze s tym Iconbar Additions. A ked tam mas Iconbar Additions tak tento ti je podla mna na nic.
Odkial ho mas? Ja som ho nikde nevidel...
>Daruj krv< |
maugliknm badatel
Posted: Mon Mar 24, 2008 7:16 pm Post subject: |
no to vies musis citat aj medzi riadkami je z
svn://svn.boba.su/ARM/PatchIconBar
no GPRS ukazoval aj mne a este malu ikonu od TXT suboru.a mimochodom ked som aplikoval tak prestal fungovat ikonbar addon a MS icons sucasne no a este aj tie hodiny.nejde o to ako tam dostat dalsie ikony ale ako ikonbar rozsirit na vatsi pocet ikon ako je 6 aby v niektorych pripadoch neblikal opreteky.
a ktoru verziu iconbar clock pouzivas?s povodnou grafikou?
Posted: Tue Mar 25, 2008 7:58 pm Post subject: |
Iconbarclock pouzivam poslednu verziu a grafiku mam inu...z s-c.ru. A musel som odstranit canvas v iconbare mainscreen positioningom lebo ked pribudla dalsia ikona tak mi z hodin odseklo.
Na modope pribudol iconbar enhancement 1.2 pre E71 tak dufam ze bude za chvilu aj pre ELko a ze to uz bude fungovat normalne
EDIT: Tak uz je aj na EL..skusil som ho a PXuje mi mobil
EDIT2: Verzia 1.1 je uz opravena ale zaujimalo by ma preco nejde ta 1.2
>Daruj krv< |
maugliknm badatel
Posted: Tue Mar 25, 2008 8:19 pm Post subject: |
predbehol si ma svimol som si ze 1.1 bola dnes aktualizovana tak skusil a ide
27.3 Nazdar spamer uz je opravena aj verzia 1.2, na tie hodiny som sa pytal lebo mne pixovali ale uz je to ok hodil som tam extrainfo 2.52 a som spokojny na MS bez hodin mimo aj hodiny v grafike co som chcel.
maugliknm badatel
maugliknm badatel
Posted: Fri Dec 26, 2008 1:00 am Post subject: |
Own folder icon 2
EL71v45
Ikony sa teraz dávajú do 2:\Ficons\
Názov ikony: názov zložky.png
Prikladám aj nejaké ikonky...názvy si už musí dať každý podľa seba
| Description:
Screen
| Filename:
| Filesize:
28.15 KB
| Downloaded:
461 Time(s)
Ficons.zip
| Description:
Ikony
| Filename:
Ficons.zip
| Filesize:
61.92 KB
| Downloaded:
548 Time(s)
Own_folder_icon2.vkp
| Description:
Patch
| Filename:
| Filesize:
1.39 KB
| Downloaded:
504 Time(s)
>Daruj krv< |
