:: View topic - Diskusia k funkčnosti patchov E/EL71
Goto page 1, 2, 3  Next
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Sun Mar 23, 2008 9:30 am    Post subject: Diskusia k funkčnosti patchov E/EL71 Reply with quote
Mozno sem budu pisat max. 2-3 ludia, ale takato tema mi tu chybala Mr. Green
Tak zacnem
Skusal niekto patch Iconbar enhancement v1.1? Mne sa po aplikovani ikonbar zaplni cervenymi stvorcekmi (1. obrazok vo FW). Sefinko pisal ze mu to robi tiez. Robi to kazdemu?
>Daruj krv<
maugliknm
Phone: EL 71,E71
645.34 SMM
PostPosted: Sun Mar 23, 2008 1:54 pm    Post subject: Reply with quote
U mna ten isty efekt,myslel som ze chyba je u mna lebo toho tam mam pomerne dost vela ale ako vidim niesom sam.mozno by nebolo odveci skusit zrusit vsetky pachte co maju nieco s ikonbarom a nechat iba
Elfs can add icons to iconbar v1
moze to mat nejaky konflikt s Iconbar Additions v3.6 - v3.7,
a nemas chut skusit aj toto:
http://forum.s-c.ru/download/296928_250%20SMS%20in%20phone%20memory_EL71v45.vkp_s-c.ru.mid
http://forum.s-c.ru/download/296929_250%20SMS%20in%20phone%20memory_E71v45.vkp_s-c.ru.mid
Podla toho co mas ci to funguje?
S 65 fw 58, M(CX) 75 fw 13,S 75 fw 47+,EL 71 fw 45,E71 fw 45 all MP 14 + EP 2.3
Jabber conference [email protected]
http://www.imghosting.eu/gallery.php?u=maugliknm
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Sun Mar 23, 2008 2:15 pm    Post subject: Reply with quote
Ja tam Iconbar Additions nemam. Ked ho chcem aplikovat, v_klay mi hlasi chybu a netusim s cim by to mohlo kolidavat Confused
A neviem o ziadnom patchi s iconbarom ze by som tam mal neviem Think Ale tiez tam mam toho dost...
Ten patch s tymi SMS veru nemam chut skusat Razz Ja SMS vacsinou mazem, takze ho nepotrebujem
>Daruj krv<
maugliknm
Phone: EL 71,E71
645.34 SMM
PostPosted: Sun Mar 23, 2008 4:44 pm    Post subject: Reply with quote
ot a mas aplikovany Sound on data transfer request v2-MP mne prestal fungovat po aplykovani niecoho ineho a s opravnym patchom som daval iba elfpack a Functions Library a to ich mam celkovo asi 100
PostPosted: Sun Mar 23, 2008 7:21 pm    Post subject: Reply with quote
Označil som ako dôležité Wink
maugliknm
Phone: EL 71,E71
645.34 SMM
PostPosted: Mon Mar 24, 2008 10:32 am    Post subject: Reply with quote
prave sa divam na iconbar enhancement v1.1 el71 fw 45 a data
05C09F4: 00213C30002206C004C0 00488047,0xA006A619,C046
05C0A24: E7480C224830E449 00488047,0xA006A629
05C0A56: DB480C224830D74937F2 014880470000,0xA006A629
05C0AD6: BB480C224830B74937F2 014880470000,0xA006A629
05C0DE4: 291C062037F216EA0E1C 00498847,0xA006A639,C046
05C0E08: 0C21 C046
05C0F54: 9F4874390E804E800C2248309D4937F2 74390E804E80014880470000,0xA006A629
05C13E6: 988A062802D906209882 C046,00488047,0xA006A653
05C143C: 998A062901D3062819D268480C22311C 00498847,0xA006A669,C046,014880470000
05C144C: 683036F2 0xA006A629
05C149C: 06220092514A6800 004A9047,0xA006A68D
05C14DC: 68005C32115A0C233C3A 00488047,0xA006A6B3,C046
05C14F6: 3C4A1030040468005C32 C046,004A9047,0xA006A6C9
05C1510: 0C23 C046
sa zhoduju s E 71 , mozno je probem niekde tam,nezda sa mi ze by EL a E mali rodielne iba adresy na ktorych je patch ulozeny,ide to niekomu na E 71 ????????????
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Mon Mar 24, 2008 1:24 pm    Post subject: Reply with quote
A co sa ti na tom nezda? To je normalne ze data su rovnake a len adresy rozdielne.
Ten patch nemam. Ja s opravnym patchom vacsinou radsej nedavam. Elfpack davam hned na cistu FF tak s nim tiez nastastie nemam problem.
>Daruj krv<
maugliknm
Phone: EL 71,E71
645.34 SMM
PostPosted: Mon Mar 24, 2008 5:54 pm    Post subject: Reply with quote
skus toto http://www.edisk.cz/stahnout-soubor/39878/OwnIconBar_el71v45_-_old.vkp_3.66KB.html
mne nejde ani to presnejsie ide pri nahravani konflikt s niecim a potom som mal v ikonbar nejaku ikonu a chybli mi ikon z ikonbar addon
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Mon Mar 24, 2008 7:03 pm    Post subject: Reply with quote
Aplikovalo mi ho bez chyby a v ikonbare mi pribudla ikona vibracii a gprs, ale zmizli mi iconbarclock.
Kolidovat ti to moze s tym Iconbar Additions. A ked tam mas Iconbar Additions tak tento ti je podla mna na nic.
Odkial ho mas? Ja som ho nikde nevidel...
>Daruj krv<
maugliknm
Phone: EL 71,E71
645.34 SMM
PostPosted: Mon Mar 24, 2008 7:16 pm    Post subject: Reply with quote
no to vies musis citat aj medzi riadkami je z
svn://svn.boba.su/ARM/PatchIconBar
no GPRS ukazoval aj mne a este malu ikonu od TXT suboru.a mimochodom ked som aplikoval tak prestal fungovat ikonbar addon a MS icons sucasne no a este aj tie hodiny.nejde o to ako tam dostat dalsie ikony ale ako ikonbar rozsirit na vatsi pocet ikon ako je 6 aby v niektorych pripadoch neblikal opreteky.
a ktoru verziu iconbar clock pouzivas?s povodnou grafikou?
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Tue Mar 25, 2008 7:58 pm    Post subject: Reply with quote
Iconbarclock pouzivam poslednu verziu a grafiku mam inu...z s-c.ru. A musel som odstranit canvas v iconbare mainscreen positioningom lebo ked pribudla dalsia ikona tak mi z hodin odseklo.
Na modope pribudol iconbar enhancement 1.2 pre E71 tak dufam ze bude za chvilu aj pre ELko a ze to uz bude fungovat normalne Pray
EDIT: Tak uz je aj na EL..skusil som ho a PXuje mi mobil Sad
EDIT2: Verzia 1.1 je uz opravena Very Happy ale zaujimalo by ma preco nejde ta 1.2
>Daruj krv<
maugliknm
Phone: EL 71,E71
645.34 SMM
PostPosted: Tue Mar 25, 2008 8:19 pm    Post subject: Reply with quote
predbehol si ma svimol som si ze 1.1 bola dnes aktualizovana tak skusil a ide
27.3 Nazdar spamer uz je opravena aj verzia 1.2, na tie hodiny som sa pytal lebo mne pixovali ale uz je to ok hodil som tam extrainfo 2.52 a som spokojny na MS bez hodin mimo aj hodiny v grafike co som chcel.
maugliknm
Phone: EL 71,E71
645.34 SMM
PostPosted: Fri Dec 19, 2008 3:45 pm    Post subject: Reply with quote
Own folder icon
(c) BingK(binghelingxi)
(p) ahk
Just put a icon.png under the folder.
http://www.sendspace.com/file/1ppi89
testovane.
maugliknm
Phone: EL 71,E71
645.34 SMM
PostPosted: Thu Dec 25, 2008 7:35 pm    Post subject: EL 71 fw 45 Reply with quote
Keys add-on for Card-Explorer
(p) Виктор89
preklad Duku
Pridava funkcie na tlacidla v Card-Explorer
http://www.sendspace.com/file/816ruq
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Fri Dec 26, 2008 1:00 am    Post subject: Reply with quote
Own folder icon 2
EL71v45
Ikony sa teraz dávajú do 2:\Ficons\
Názov ikony: názov zložky.png
Prikladám aj nejaké ikonky...názvy si už musí dať každý podľa seba Smile
 081226_004814.jpg | Description: Screen | Filename: 081226_004814.jpg | Filesize: 28.15 KB | Downloaded: 462 Time(s)
 Ficons.zip | Description: Ikony | Filename: Ficons.zip | Filesize: 61.92 KB | Downloaded: 549 Time(s)
 Own_folder_icon2.vkp | Description: Patch | Filename: Own_folder_icon2.vkp | Filesize: 1.39 KB | Downloaded: 505 Time(s)
>Daruj krv<
Page 1 of 3
